查看: 1067|回复: 1
gambit新手求助!哪位大侠指点一下,不胜感激!!!
发表于 2003-11-18 17:07:42 | 显示全部楼层 |阅读模式
我刚开始学用gambit,试着做了一个圆柱体,网格化后保存然后退出,可下次打开gambit 时,界面上仍显示上次做的圆柱体,我想再做别的几何体,请问怎样才能把当前的圆柱取消呀?
  还有,gambit好象和exceed不可分割,exceed有什么作用呀?好象在使用gambit是并不怎么用exceed,以上问题拜请大侠指点迷津!!
发表于 2003-11-18 19:40:33 | 显示全部楼层
a file "filename".dbs will be saved in your working directory when you save the session, the "fileanme" can be specified using command-line options -id filename.
if you don't specify the -id option, a name "default" will be used. therefore when you save the session, a file default.dbs will exist in your working directory, next time you restart Gambit from the same directory, it will read in data from this file.
Two options,
use -id filename with a different name if you always start Gambit from the same directory, or set up another working directory
or
use reset command to clear the current model
