查看: 1792|回复: 2
DPM 里面使用Plain-Orifice喷雾时喷嘴内径为什么要小于5mm?
发表于 2017-5-21 22:18:28 | 显示全部楼层 |阅读模式
设置内径大于5mm后出现
Injection injection-0: "Inner Diameter" (0.0151) is larger than "Outer Diameter" (0.005). This is not supported.
这是为什么呢??
 楼主| 发表于 2017-5-24 09:32:03 | 显示全部楼层
自顶一下
 楼主| 发表于 2017-5-31 19:50:34 | 显示全部楼层
来自安世亚太的回复:
I have a reply from the development team. The warning message you see will not affect your calculation. You can specify any value of inner diameter without worrying about the outer diameter and you can safely ignore the warning message.
This warning message appears because of a bug. Currently, you cannot specify the outer diameter through GUI and hence the value of outer diameter is fixed at a default value of 0.005 m. However, this value does not affect the calculation and you can specify a larger value for inner diameter. This bug has been fixed in R18.2 so that you will be able to specify outer diameter through GUI.
