查看: 1080|回复: 3
刚开始学fluent遇到个问题,请问如何解决?
发表于 2004-3-24 22:41:10 | 显示全部楼层 |阅读模式
我刚开始学fluent,跟着帮助里面的例子做(第1个),首次很正常。可第二天接着看的时候就出问题了,错误如图片显示。请问为什么display不能显示了??
发表于 2004-3-25 00:01:09 | 显示全部楼层
看提示好像是显卡驱动的问题!
发表于 2004-3-25 04:43:15 | 显示全部楼层
You could check the results to see whether they are correct.
I have experienced the same problem and just do iteration again, the results agree with the experiments data still very well.
I also don't know the reason
You could save case&data and quit. Then start fluent again and load the case&data. I found the display worked again
发表于 2004-3-25 13:32:03 | 显示全部楼层
我想应该是显示的问题,你把显示窗口关了重新试一下!
