查看: 1206|回复: 5
[求助]我的GAMBIT怎么启动不了?
发表于 2004-9-3 11:22:07 | 显示全部楼层 |阅读模式
总有这样的出错信息,不知是为什么?各位请帮帮我,非常感谢!
发表于 2004-9-3 12:00:49 | 显示全部楼层
[求助]我的GAMBIT怎么启动不了?
tannoydw
 楼主| 发表于 2004-9-3 12:08:24 | 显示全部楼层
[求助]我的GAMBIT怎么启动不了?
请帮我解决以下问题
发表于 2004-9-3 12:12:53 | 显示全部楼层
[求助]我的GAMBIT怎么启动不了?
Hoops....
mistake!
  tannoydw:
If you've already seen my solution for others, you wouldn't ask the same question.
The reason why happened is that you cannot set up SERVER line properly at the top of license if you are using license software (FLEXlm).
My suggestion is that you needn't install or use such software if you are not sure how to use it instead of locating license at the following path:
C:\fluent.inc\license
That's a default path for software to search for license while software starts.
OK, help all helps!!
发表于 2004-9-3 12:50:34 | 显示全部楼层
[求助]我的GAMBIT怎么启动不了?
只有把x:\Fluent.Inc\ntbin\ntx86目录下的以default_id开头的文件删掉就行了。
 楼主| 发表于 2004-9-4 20:04:16 | 显示全部楼层
[求助]我的GAMBIT怎么启动不了?
谢谢各位
历经千辛万苦,终于ok了:)
特别致谢 carljian  和pemfc
