查看: 2886|回复: 0
网格导入fluent出现警告
发表于 2018-11-29 20:22:25 | 显示全部楼层 |阅读模式
The mesh contains high aspect ratio quadrilateral,  hexahedral, or polyhedral cells.
The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells.
Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance.
Please select /solve/initialize/repair-wall-distance   using the text user interface to switch to the alternative algorithm.
但按照提示找不到repair-wall-distance
希望解答
