查看: 7895|回复: 3
求助 Process affinity not being set pcount > npes?
发表于 2020-11-30 09:52:59 | 显示全部楼层 |阅读模式
在Fluent 2020R1中导入.mesh文件出现以下提示:
> Note: Rank = 11: Process affinity not being set pcount > npes
Note: Rank = 29: Process affinity not being set pcount > npes
Note: Rank = 30: Process affinity not being set pcount > npes
Note: Rank = 44: Process affinity not being set pcount > npes
Note: Rank = 21: Process affinity not being set pcount > npes
Note: Rank = 43: Process affinity not being set pcount > npes
Note: Rank = 0: Process affinity not being set pcount > npes
Note: Rank = 2: Process affinity not being set pcount > npes
Note: Rank = 5: Process affinity not being set pcount > npes
Note: Rank = 9: Process affinity not being set pcount > npes
Note: Rank = 12: Process affinity not being set pcount > npes
Note: Rank = 19: Process affinity not being set pcount > npes
Note: Rank = 23: Process affinity not being set pcount > npes
Note: Rank = 28: Process affinity not being set pcount > npes
Note: Rank = 34: Process affinity not being set pcount > npes
Note: Rank = 40: Process affinity not being set pcount > npes
Note: Rank = 1: Process affinity not being set pcount > npes
Note: Rank = 4: Process affinity not being set pcount > npes
Note: Rank = 6: Process affinity not being set pcount > npes
Note: Rank = 7: Process affinity not being set pcount > npes
Note: Rank = 8: Process affinity not being set pcount > npes
Note: Rank = 15: Process affinity not being set pcount > npes
Note: Rank = 18: Process affinity not being set pcount > npes
Note: Rank = 20: Process affinity not being set pcount > npes
Note: Rank = 22: Process affinity not being set pcount > npes
Note: Rank = 25: Process affinity not being set pcount > npes
Note: Rank = 26: Process affinity not being set pcount > npes
Note: Rank = 27: Process affinity not being set pcount > npes
Note: Rank = 36: Process affinity not being set pcount > npes
Note: Rank = 37: Process affinity not being set pcount > npes
Note: Rank = 39: Process affinity not being set pcount > npes
Note: Rank = 45: Process affinity not being set pcount > npes
Note: Rank = 46: Process affinity not being set pcount > npes
Note: Rank = 48: Process affinity not being set pcount > npes
Note: Rank = 3: Process affinity not being set pcount > npes
Note: Rank = 10: Process affinity not being set pcount > npes
Note: Rank = 17: Process affinity not being set pcount > npes
Note: Rank = 24: Process affinity not being set pcount > npes
Note: Rank = 32: Process affinity not being set pcount > npes
Note: Rank = 16: Process affinity not being set pcount > npes
Note: Rank = 31: Process affinity not being set pcount > npes
Note: Rank = 35: Process affinity not being set pcount > npes
Note: Rank = 38: Process affinity not being set pcount > npes
Note: Rank = 42: Process affinity not being set pcount > npes
Note: Rank = 47: Process affinity not being set pcount > npes
Note: Rank = 49: Process affinity not being set pcount > npes
Note: Rank = 33: Process affinity not being set pcount > npes
Note: Rank = 14: Process affinity not being set pcount > npes
Note: Rank = 13: Process affinity not being set pcount > npes
Note: Rank = 41: Process affinity not being set pcount > npes
请问哪里出问题了呢,谢谢大佬!
发表于 2021-1-8 20:58:52 | 显示全部楼层
我最近用fluent15并行计算也出现了类似的问题了  请问楼主解决了吗?
好像没有,我觉得是网格问题  详情 回复 发表于 2021-7-20 16:47
 楼主| 发表于 2021-7-20 16:47:15 | 显示全部楼层
没有
 楼主| 发表于 2021-7-20 16:47:55 | 显示全部楼层
好像没有,我觉得是网格问题
