查看: 2928|回复: 3
柱塞泵仿真算两步就发散了
发表于 2023-5-24 19:46:55 | 显示全部楼层 |阅读模式
貌似回流严重,但是出口管道已经加到管子直径的20倍了    用k-omiga算的  网格检查如图求大佬给点建议
登录/注册后可看大图
 楼主| 发表于 2023-5-24 19:53:27 | 显示全部楼层
怎么图片发上不来...
 楼主| 发表于 2023-5-24 20:09:25 | 显示全部楼层
图
 楼主| 发表于 2023-5-24 20:11:44 | 显示全部楼层
Artificial walls on 1 face (0.0% area) of pressure-outlet 99 to prevent fluid from flowing into the boundary.
Artificial walls on 2040 faces (90.4% area) of pressure-outlet 113 to prevent fluid from flowing into the boundary.
Artificial walls on 1642 faces (72.8% area) of pressure-outlet 114 to prevent fluid from flowing into the boundary.
Artificial walls on 780 faces (100.0% area) of pressure-outlet 138 to prevent fluid from flowing into the boundary.
图上不来 内容是这样的
