查看: 2794|回复: 1
CFX多级压气机仿真遇到问题
发表于 2023-12-10 11:10:30 | 显示全部楼层 |阅读模式
请教一下各位,在CFX中仿真多级压气机,每一级是动叶+静叶的组合,一级一级载入测试,当加载到第七级(14个叶片)的时候,出现了“Cannot write terminator to out file: Permission denied”的错误,然后跳出来的报错信息是:The ANSYS CFX solver exited with return code 1. No results file has been created.
前面几级都是正常的,是有模型数量的限制吗?请问有谁知道原因吗?谢谢。
OUTER LOOP ITERATION =  688 (    8) CPU SECONDS = 2.617E+05 (7.083E+03)
|       Equation       | Rate | RMS Res | Max Res |  Linear Solution |
| U-Mom                | 0.64 | 1.0E-03 | 2.8E-01 |       6.8E-02  OK|
| V-Mom                | 0.83 | 7.2E-04 | 1.2E-01 |       1.0E-01  ok|
| W-Mom                | 0.66 | 1.4E-03 | 2.1E-01 |       1.4E-01  ok|
| P-Mass               | 1.36 | 3.1E-04 | 9.6E-02 |  9.2  5.9E-02  OK|
| ERROR #004100018 has occurred in subroutine FINMES.                |
| Fatal overflow in linear solver.
发表于 2024-1-2 11:00:12 | 显示全部楼层
你好,问题解决了吗
