查看: 5563|回复: 8
那位大哥知道计算流体力学新进展吗?急需!!!
发表于 2002-4-3 15:13:47 | 显示全部楼层 |阅读模式
      有那位大哥知道有关计算流体力学新进展或新动态吗?能告诉我有关网站或书目吗?
发表于 2002-4-4 03:44:38 | 显示全部楼层
which kind of development do you want to know ?
I means which kind of work you are doing .
发表于 2002-4-4 07:38:15 | 显示全部楼层
i also want to know that,now i am working about the air-conditioner,but my major is fluid mechanics,thanks for your attention
发表于 2002-4-4 08:05:49 | 显示全部楼层
I am sorry I just know something on aerospace engineering , but I will pay attention your direction later, and if I find something useful to you, I will let you know and send them to you.
 楼主| 发表于 2002-4-4 20:48:19 | 显示全部楼层
我需要的是新的计算流体力学的计算方法,请各位大哥帮忙,拜托!!
 楼主| 发表于 2002-4-5 09:05:39 | 显示全部楼层
Thank you,boling2000,老人头马,for your help!!!!
发表于 2002-4-9 14:15:37 | 显示全部楼层
西安交通大学的陶文铨教授的专著:《计算传热学的近代进展》里面讲了很多近年来常用的新方法,其中包括网格生成方面的、对流项离散格式、压力-速度耦合关系、边界条件等等
此外,还介绍了一些商业CFD软件的优缺点、一些方法的源代码及一些网址。
是一本很不错的书。里面很多东西虽然是传热方面的,但大部分都可以用到CFD中。
 楼主| 发表于 2002-4-9 15:48:01 | 显示全部楼层
谢谢redboy的指点!!!
发表于 2002-4-12 05:01:31 | 显示全部楼层
Tao Wenquan's good is very good and I think you can use it if you are not in mathematics major. The book can be downloaded using SSReader as I know... Good luck!
