查看: 2447|回复: 5
[求助]斑竹大哥,为什么这个例子不能运算啊?
发表于 2004-8-29 22:20:08 | 显示全部楼层 |阅读模式
   我的图书馆里面的F308为什么不能运算呢,好象温度场和流场叠加的例子不少都不能算,怎么回事?我用的3.4,只有CORE,下为Q1文件,帮我看看,这个例子对我很有帮助。
   Q1 created by VDI menu, Version 3.1, Date 7 JULY 1997
CPVNAM=VDI;SPPNAM=Core
  Group 1. Run Title
TEXT(FGE: Backward facing step with KEMODL model
  Groups 3, 4, 5  Grid Information
    * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,16,8,1)
    * Set overall domain extent:
    *        xulast  yvlast  zwlast    name
XSI= 8.000E-01;YSI= 1.200E-01;ZSI= 1.000E+00;RSET(D,CHAM    )
    * Set objects: x0     y0     z0
    *              dx     dy     dz    name
XPO= 0.000E+00;YPO= 0.000E+00;ZPO= 0.000E+00
XSI= 1.600E-01;YSI= 4.000E-02;ZSI= 1.000E+00;RSET(B,B1      )
XSI= 8.000E-02;YSI= 1.200E-02;ZSI= 1.000E+00;RSET(B,B2      )
XPO= 0.000E+00;YPO= 4.000E-02;ZPO= 0.000E+00
XSI= 0.000E+00;YSI= 8.000E-02;ZSI= 1.000E+00;RSET(B,B3      )
XPO= 8.000E-01;YPO= 0.000E+00;ZPO= 0.000E+00
XSI= 0.000E+00;YSI= 1.200E-01;ZSI= 1.000E+00;RSET(B,B4      )
XPO= 0.000E+00;YPO= 1.200E-01;ZPO= 0.000E+00
XSI= 8.000E-01;YSI= 0.000E+00;ZSI= 1.000E+00;RSET(B,B5      )
XPO= 1.600E-01;YPO= 0.000E+00;ZPO= 0.000E+00
XSI= 6.400E-01;YSI= 0.000E+00;ZSI= 1.000E+00;RSET(B,B6      )
XPO= 1.000E-01;YPO= 0.000E+00;ZPO= 0.000E+00
XSI= 4.000E-01;YSI= 6.000E-02;ZSI= 1.000E+00;RSET(B,B8      )
XSI= 3.600E-01;YSI= 0.000E+00;ZSI= 1.000E+00;RSET(B,B9      )
  Group 7. Variables: STOREd,SOLVEd,NAMEd
    * Solved variables list
#solvel
#soltem
TURMOD(KEMODL)
    * Stored variables list
STORE(PRPS)
  Group 9. Properties
PRESS0 = 1.000E+05 ; TEMP0  = 2.730E+02
  Group 11.Initialise Var/Porosity Fields
FIINIT(TEM1) =  0.000E+00
  Group 15. Terminate Sweeps
LSWEEP  =     250
TSTSWP  =    -1
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 5.000000E-01)
RELAX(U1  ,FALSDT, 1.000000E+02)
RELAX(V1  ,FALSDT, 1.000000E+02)
RELAX(TEM1,LINRLX, 1.000000E+00)
KELIN   =       1
  Group 22. Monitor Print-Out
IXMON   =      10 ;IYMON  =       8 ;IZMON  =       1
NPRMNT  =       1
  Group 24. Dumps For Restarts
GVIEW(P,0.000000E+00,-7.073728E-02,9.974950E-01)
GVIEW(UP,0.000000E+00,9.974950E-01,7.073728E-02)
> DOM,    SIZE,        8.000000E-01, 1.200000E-01, 1.000000E+00
> DOM,    MONIT,       5.000000E-01, 1.200000E-01, 1.000000E-01
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E-01
> DOM,    SNAPSIZE,    1.000000E-02
> DOM,    SURTEMP,     0.000000E+00
> DOM,    FLOWTYPE,          2
> DOM,    RELAX,       5.000000E-01
> OBJ1,   NAME,        B1
> OBJ1,   POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ1,   SIZE,        1.600000E-01, 4.000000E-02, 1.000000E+00
> OBJ1,   CLIPART,     default
> OBJ1,   ROTATION,          1
> OBJ1,   TYPE,        BLOCKAGE
> OBJ1,   MATERIAL,      198
> OBJ2,   NAME,        B2
> OBJ2,   POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ2,   SIZE,        8.000000E-02, 1.200000E-02, 1.000000E+00
> OBJ2,   CLIPART,     default
> OBJ2,   ROTATION,          1
> OBJ2,   TYPE,        BLOCKAGE
> OBJ2,   MATERIAL,      198
> OBJ3,   NAME,        B3
> OBJ3,   POSITION,    0.000000E+00, 4.000000E-02, 0.000000E+00
> OBJ3,   SIZE,        0.000000E+00, 8.000000E-02, 1.000000E+00
> OBJ3,   CLIPART,     default
> OBJ3,   ROTATION,          1
> OBJ3,   TYPE,        INLET
> OBJ3,   VELOCITY,      1.300000E+01, 0.000000E+00, 0.000000E+00
> OBJ3,   TEMPERATURE,   2.000000E+01
> OBJ4,   NAME,        B4
> OBJ4,   POSITION,    8.000000E-01, 0.000000E+00, 0.000000E+00
> OBJ4,   SIZE,        0.000000E+00, 1.200000E-01, 1.000000E+00
> OBJ4,   CLIPART,     default
> OBJ4,   ROTATION,          1
> OBJ4,   TYPE,        OUTLET
> OBJ4,   TEMPERATURE,   0.000000E+00
> OBJ4,   PRESSURE,      0.000000E+00
> OBJ4,   COEFFICIENT,   1.000000E+03
> OBJ5,   NAME,        B5
> OBJ5,   POSITION,    0.000000E+00, 1.200000E-01, 0.000000E+00
> OBJ5,   SIZE,        8.000000E-01, 0.000000E+00, 1.000000E+00
> OBJ5,   CLIPART,     default
> OBJ5,   ROTATION,          1
> OBJ5,   TYPE,        PLATE
> OBJ5,   POROSITY,      0.000000E+00
> OBJ5,   HEAT,          2.000000E+03
> OBJ6,   NAME,        B6
> OBJ6,   POSITION,    1.600000E-01, 0.000000E+00, 0.000000E+00
> OBJ6,   SIZE,        6.400000E-01, 0.000000E+00, 1.000000E+00
> OBJ6,   CLIPART,     default
> OBJ6,   ROTATION,          1
> OBJ6,   TYPE,        PLATE
> OBJ6,   POROSITY,      0.000000E+00
> OBJ6,   HEAT,          0.000000E+00
> OBJ7,   NAME,        B8
> OBJ7,   POSITION,    1.000000E-01, 0.000000E+00, 0.000000E+00
> OBJ7,   SIZE,        4.000000E-01, 6.000000E-02, 1.000000E+00
> OBJ7,   CLIPART,     fine
> OBJ7,   ROTATION,          1
> OBJ7,   TYPE,        FINE_GRID_VOL
> OBJ7,   FINEFACTS,     4.000000E+00, 4.000000E+00, 1.000000E+00
> OBJ8,   NAME,        B9
> OBJ8,   POSITION,    1.600000E-01, 0.000000E+00, 0.000000E+00
> OBJ8,   SIZE,        3.600000E-01, 0.000000E+00, 1.000000E+00
> OBJ8,   CLIPART,     default
> OBJ8,   ROTATION,          1
> OBJ8,   TYPE,        PLATE
> OBJ8,   POROSITY,      0.000000E+00
> OBJ8,   HEAT,          0.000000E+00
M
发表于 2004-8-30 10:32:07 | 显示全部楼层
我的就可以算啊,你看
发表于 2004-8-30 10:32:48 | 显示全部楼层
这是压力场
 楼主| 发表于 2004-8-30 10:50:58 | 显示全部楼层
   好兄弟,你再帮我看看Y302,我真羡慕死你了,你的3。5。1就是与众不同啊,能否加你为好友,31474170
发表于 2004-8-30 10:56:47 | 显示全部楼层
呵呵,举手之劳,我的3.5.1也算不出y302还没有算就跳出来了,不知道怎么回事,好象是适体网格.我刚才加你了
发表于 2004-9-3 12:56:44 | 显示全部楼层
那位大侠能把Y302,Y303给算出来或给检查一下Q1文件,感激中。。。。
