查看: 2294|回复: 0
请问:关于斜面入口
发表于 2004-11-9 10:46:00 | 显示全部楼层 |阅读模式
phoenics无法设定斜面inlet,是否只能设定薄的blockage,在其attributes的momentum source里设定fixed velocity?
那此时energy source设定fixed temperature和在inlet中设定的temperature作用是相同的吗?
另外,inlet可以设定气体的密度,在blockage好像没法设,是否只能改变props文件?
下面是我计算的一个很简单的算例,大家帮忙看看问题出在哪里,多谢啦~
TALK=T;RUN( 1, 1)
  Q1 created by VDI menu, Version 3.5, Date 20/10/03
CPVNAM=VDI;SPPNAM=Core
IRUNN   =         1 ;LIBREF =         0
Group 1. Run title
TEXT(No title has been set for this run.     )
Group 2. Transience
STEADY  =    T
Groups 3, 4, 5  Grid Information
   * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,20,1,20)
Group 6. Body-Fitted coordinates
Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
NAME(150) =TEM1
SOLVE(P1  ,U1  ,W1  ,TEM1)
   * Additional solver options
SOLUTN(P1  ,Y,Y,Y,N,N,Y)
SOLUTN(TEM1,Y,Y,Y,N,N,Y)
Group 8. Terms & Devices
TERMS (TEM1,Y,Y,Y,Y,Y,Y)
Group 9. Properties
PRESS0  = 1.000000E+05 ;TEMP0  = 2.730000E+02
SETPRPS(1,  0)
ENUT    = 0.000000E+00
DVO1DT  = 3.410000E-03
PRNDTL(TEM1) =  1.000000E+00
Group 10.Inter-Phase Transfer Processes
Group 11.Initialise Var/Porosity Fields
FIINIT(P1  ) =  0.000000E+00 ;FIINIT(U1  ) =  0.000000E+00
FIINIT(W1  ) =  1.000000E+01 ;FIINIT(TEM1) =  1.000000E+01
  No PATCHes used for this Group
INIADD  =    F
Group 12. Convection and diffusion adjustments
Group 13. Boundary & Special Sources
EGWF    =    T
Group 14. Downstream Pressure For PARAB
Group 15. Terminate Sweeps
LSWEEP  =      1000
RESFAC  = 1.000000E-03
Group 16. Terminate Iterations
Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
RELAX(U1  ,FALSDT, 1.000000E+01)
RELAX(W1  ,FALSDT, 1.000000E+01)
RELAX(TEM1,FALSDT, 1.000000E+01)
Group 18. Limits
VARMAX(U1  ) = 1.000000E+06 ;VARMIN(U1  ) =-1.000000E+06
VARMAX(W1  ) = 1.000000E+06 ;VARMIN(W1  ) =-1.000000E+06
Group 19. EARTH Calls To GROUND Station
USEGRD  =    T  ;USEGRX =    T
ASAP    =    T
PARSOL  =    T
Group 20. Preliminary Printout
ECHO    =    T
Group 21. Print-out of Variables
Group 22. Monitor Print-Out
IXMON   =        10 ;IYMON  =         1 ;IZMON  =        11
NPRMON  =    100000
NPRMNT  =         1
TSTSWP  =        -1
Group 23.Field Print-Out & Plot Control
NPRINT  =    100000
ISWPRF  =         1 ;ISWPRL =    100000
Group 24. Dumps For Restarts
GVIEW(P,-2.884631E-02,-9.945948E-01,9.974728E-02)
GVIEW(UP,7.061917E-03,9.958342E-02,9.950042E-01)
> DOM,    SIZE,        1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    MONIT,       4.750000E-01, 5.000000E-01, 5.100000E-01
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    SNAPSIZE,    1.000000E-02
> OBJ,    NAME,        B1
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ,    SIZE,        1.000000E+00, 1.000000E+00, 2.000000E-02
> OBJ,    CLIPART,     cubet1
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        BLOCKAGE
> OBJ,    MATERIAL,        0
> OBJ,    FIXED_TMP,     0.000000E+00, 2.000000E+02
> OBJ,    FIX_VAL_Z,     FIXVAL      , 2.000000E+01
> OBJ,    SCAL_FIXF,     0.000000E+00
> OBJ,    INI_VEL_Z_1,   2.000000E+01
> OBJ,    NAME,        B2
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 1.000000E+00
> OBJ,    SIZE,        1.000000E+00, 1.000000E+00, 0.000000E+00
> OBJ,    CLIPART,     cube12t
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OUTLET
> OBJ,    PRESSURE,      0.000000E+00
> OBJ,    TEMPERATURE,   SAME
> OBJ,    COEFFICIENT,   1.000000E+03
> OBJ,    VELOCITY,      SAME        , SAME        , SAME
STOP
