查看: 4090|回复: 3
瞬态问题这样建模型是否可行,帮我看看
发表于 2005-11-17 12:35:18 | 显示全部楼层 |阅读模式
我作的是封闭腔的自然对流问题,有夹层的,我需要知道壁面的温度变化过程,所以我加了几个那样的Probe,不知道对否
 楼主| 发表于 2005-11-23 13:22:59 | 显示全部楼层
瞬态问题这样建模型是否可行,帮我看看
请斑竹删除本帖好了,我问题已经解决了
 楼主| 发表于 2005-11-23 13:28:40 | 显示全部楼层
瞬态问题这样建模型是否可行,帮我看看
initialisation---multi-run starts from previous run--yes
换成yes后,他就可以接着上次的结果运行,比如你第一次迭代10次,这次迭代20次,那么最后的结果便是迭代30次后的结果
field simulation has been undertaken for a sector, the simulation can be continued by using the restart facility. Restart means that the solution from the former run is used for the initial conditions. In situations when the number of iterations specified in the preceding simulations have not led to a converged solutions, a restart could progress the solution further towards convergence. Default value is False
1.In Phoenics VR Editor - File/load from library 2.In case nember - c113 3.Ok 4.Enter (choose main calculation) 5.Run/solver 6.After that - copy phi-file from c:/phoenics/d_priv in another directory (for exemple in desktop) 7.Repeat 1-3 8.In sattelite command promt insert P (post-processing calculations) 9.Replace phi-file in c:/phoenics/d_priv 10.Go to Phoenics menu, initialisation. Put "restart for all variables". 11.Run/solver 12.Thats all
发表于 2005-12-2 14:27:50 | 显示全部楼层
瞬态问题这样建模型是否可行,帮我看看
initialisation中multi-run starts from previous run这个命令行我怎么没有呢?你用的是什么版本?
