查看: 1510|回复: 0
请教各位!多帮忙,谢谢!
发表于 2003-11-1 23:17:09 | 显示全部楼层 |阅读模式
[这个贴子最后由xlfd在 2003/11/01 11:31pm 第 1 次编辑]
我是新手,先在CAD 中做了个实体,在实体内部开了两个相互垂直的三角槽,导入到phoenics中,外围尺寸设的和实体一样大,入口设在west出口在east,运行earth后不太行,
请教原因,及网格划分方法!用的是phoenics3.3,请各位帮忙!
上传实体图bmp格式,
和q1文件!
ALK=T;RUN( 1, 1)
   Q1 created by VDI menu, Version 3.3, Date 10/02/00
CPVNAM=VDI;SPPNAM=Core
IRUNN   =       1 ;LIBREF =       0
  Group 1. Run Title
TEXT(fluent1                                 )
  Group 2. Transience
STEADY  =    T
  Groups 3, 4, 5  Grid Information
    * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,20,15,20)
    * Set overall domain extent:
    *        xulast  yvlast  zwlast
            name
XSI= 8.000000E-02; YSI= 8.000000E-02; ZSI= 6.280000E-03
RSET(D,CHAM    )
  Group 6. Body-Fitted coordinates
  Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
NAME(150) =WDIS
    * Solved variables list
SOLVE(P1  ,U1  ,V1  ,W1  )
    * Stored variables list
STORE(WDIS)
    * Additional solver options
SOLUTN(P1  ,Y,Y,Y,N,N,Y)
TURMOD(LVEL)
  Group 8. Terms & Devices
  Group 9. Properties
SETPRPS(1,  0)
RHO1    = 1.189000E+00
PRESS0  = 1.000000E+05
TEMP0   = 2.730000E+02
CP1     = 1.005000E+03
ENUL    = 1.544000E-05
DVO1DT  = 3.410000E-03
  Group 10.Inter-Phase Transfer Processes
  Group 11.Initialise Var/Porosity Fields
FIINIT(WDIS) =  6.280000E-04
   No PATCHes used for this Group
INIADD  =    F
  Group 12. Convection and diffusion adjustments
  Group 13. Boundary & Special Sources
EGWF    =    T
  Group 14. Downstream Pressure For PARAB
  Group 15. Terminate Sweeps
LSWEEP  =       1
RESFAC  = 1.000000E-03
  Group 16. Terminate Iterations
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
  Group 18. Limits
VARMAX(U1  ) = 1.000000E+06 ;VARMIN(U1  ) =-1.000000E+06
VARMAX(V1  ) = 1.000000E+06 ;VARMIN(V1  ) =-1.000000E+06
VARMAX(W1  ) = 1.000000E+06 ;VARMIN(W1  ) =-1.000000E+06
  Group 19. EARTH Calls To GROUND Station
USEGRD  =    T  ;USEGRX =    T
ASAP    =    T
  Group 20. Preliminary Printout
ECHO    =    T
  Group 21. Print-out of Variables
OUTPUT(P1  ,Y,Y,Y,N,Y,Y)
OUTPUT(U1  ,Y,Y,Y,N,Y,Y)
OUTPUT(V1  ,Y,Y,Y,N,Y,Y)
OUTPUT(W1  ,Y,Y,Y,N,Y,Y)
OUTPUT(WDIS,Y,N,N,N,N,N)
  Group 22. Monitor Print-Out
IXMON   =      10 ;IYMON  =       8 ;IZMON  =      10
NPRMON  =  100000
NPRMNT  =       1
TSTSWP  =      -1
  Group 23.Field Print-Out & Plot Control
NPRINT  =  100000
ISWPRF  =       1 ;ISWPRL =  100000
  Group 24. Dumps For Restarts
NOWIPE  =    T
GVIEW(P,0.000000E+00,-9.995590E-01,2.969560E-02)
GVIEW(UP,0.000000E+00,2.969560E-02,9.995590E-01)
> DOM,    SIZE,        8.000000E-02, 8.000000E-02, 6.280000E-03
> DOM,    MONIT,       3.800000E-02, 4.000000E-02, 2.983000E-03
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    SNAPSIZE,    1.000000E-02
> DOM,    RELAX,       5.000000E-01
> OBJ1,   NAME,        FAME
> OBJ1,   POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ1,   SIZE,        8.000000E-02, 8.000000E-02, 6.280000E-03
> OBJ1,   CLIPART,     3mm波1个实体2003
> OBJ1,   ROTATION24,        1
> OBJ1,   TYPE,        BLOCKAGE
> OBJ1,   MATERIAL,      100
> OBJ1,   FIXED_TMP,     0.000000E+00, 0.000000E+00
> OBJ2,   NAME,        INLET
> OBJ2,   POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ2,   SIZE,        0.000000E+00, 8.000000E-02, 6.280000E-03
> OBJ2,   CLIPART,     cube3t
> OBJ2,   ROTATION24,        1
> OBJ2,   TYPE,        INLET
> OBJ2,   PRESSURE,      1.189000E+00
> OBJ2,   VELOCITY,      1.000000E-01, 0.000000E+00, 0.000000E+00
> OBJ2,   TEMPERATURE,   0.000000E+00
> OBJ3,   NAME,        OUTLET
> OBJ3,   POSITION,    8.000000E-02, 0.000000E+00, 0.000000E+00
> OBJ3,   SIZE,        0.000000E+00, 8.000000E-02, 6.280000E-03
> OBJ3,   CLIPART,     cube12t
> OBJ3,   ROTATION24,        1
> OBJ3,   TYPE,        OUTLET
> OBJ3,   PRESSURE,      0.000000E+00
> OBJ3,   TEMPERATURE,  -1.026000E+04
> OBJ3,   COEFFICIENT,   1.000000E+03
M
STOP
