查看: 2746|回复: 4
急问:RElAX(LTLS,FALSDT,1.00000E+00)是什么意思?是如何设置的?
发表于 2003-11-10 20:52:24 | 显示全部楼层 |阅读模式
谢谢!
发表于 2003-11-10 21:35:29 | 显示全部楼层
设置松弛因子啊,LTLS是离开壁面的距离,FALSDT是虚拟时间步长法
 楼主| 发表于 2003-11-10 21:59:12 | 显示全部楼层
在VR的numbers什么地方设,才能有效如何设?才能反应到q1文件中?
谢谢!
galary1979 请帮忙在程序上看看!
急!
发表于 2003-11-11 10:55:17 | 显示全部楼层
RELAX(variable name,FALSDT,false time step), adds a source in each cell equal to the mass in the cell divided by the size of the time step.
在第17组中设置这个命令的,正的松弛因子是采用虚拟时间步长方法的,但是具体怎么设置为多大,我还没有研究过,也没有什么经验提供
发表于 2003-11-11 11:05:02 | 显示全部楼层
最基本的是(可以查看polis中的相关介绍)
Its effect is to add to the phi-balance for each cell a source equal to:
(latest_phi - next_phi) * (mass in cell) / DTFALS(phi)
where latest_phi is the current value of the variable being solved for, and next_phi is that which it will take after adjustment.
This has the effect of making next_phi very close to latest_phi when DTFALS is large, so that changes can occur only after many repetitions of the adjustment process.
A value of DTFALS=1.E-20 would prevent change entirely on many machines, a fact which it is sometimes convenient to exploit, for example when seeking to understand the causes of divergence.
