查看: 1671|回复: 0
计算中出错,如何设置这些参数?请高手指教!谢谢!
发表于 2005-5-17 15:47:48 | 显示全部楼层 |阅读模式
****** Notice ******                           |
| Newtons method failed to converge in  100 iterations.  This        |
| occured while computing the following variable:                    |
| Variable Name  : Temperature                                       |
| Location Name  : liutiyu                                           |
| Mesh location  : VERTICES                                          |
| Mesh entity    :                                                   |
| Last 3 Changes :  5.04668E-01  3.36517E-01  5.04932E-01            |
| Tolerance      :  1.0000E-02                                       |
| The Newton iteration was either slowly converging or has stalled.  |
| The solver will continue with the variable set as it was on the    |
| final iteration.  If this situation continues you might try        |
| increasing the number of iterations allowed for Newtons method.    |
| This can be changed by setting one of the parameters:              |
| Temperature : "Constitutive Relation Iteration Limit"              |
| Pressure    : "Newton Pressure Iteration Limit"                    |
| for your mixture using the definition file editor.                 |
