查看: 2011|回复: 0
CFX中有关雷诺数的问题
发表于 2006-1-5 22:04:02 | 显示全部楼层 |阅读模式
各位好,请教一个基本问题啊,我用CFX求解一个翼型流场,翼型长度为1,矩形边界,前后远场10.单位米,结果CFX的out文件中显示:
Domain Name : Default Domain
     Global Length                                         = 4.6413E+00
     Minimum Extent                                        = 5.0000E-01
     Maximum Extent                                        = 2.0000E+01
     Density                                               = 1.2254E+00
     Dynamic Viscosity                                     = 1.8310E-05
     Velocity                                              = 1.0000E+02
     Advection Time                                        = 4.6413E-02
     Reynolds Number                                       = 3.1063E+07
     Speed of Sound                                        = 3.4027E+02
     Mach Number                                           = 2.9389E-01
     Thermal Conductivity                                  = 2.6100E-02
     Specific Heat Capacity at Constant Pressure           = 1.0044E+03
     Specific Heat Capacity at Constant Volume             = 7.1730E+02
     Specific Heat Ratio                                   = 1.4003E+00
     Prandtl Number                                        = 7.0462E-01
请问 Global Length 是什么意义啊,计算的雷诺数明显不对,温度是15度,密度是对的,
但是动粘性系数也不对阿,请问CFX中关于雷诺数的计算到底是怎么样的,还请各位不吝指教!谢谢!
