查看: 2421|回复: 1
求助:有谁用cfx计算过mach大于2的流场,尤其是燃烧?
发表于 2006-5-27 13:47:07 | 显示全部楼层 |阅读模式
我最近用cfx10计算球头激波诱导点火,结构很简单,但是mach都在3--5左右。计算很难收敛,残差跳动严重。而且有以下提示:
       ****** Notice ******                           |
| Newtons method failed to converge in  100 iterations.  This        |
| occurred while computing the following variable:                   |
| Variable Name  : Total Temperature                                 |
| Location Name  : out                                               |
| Mesh location  : BELG7                                             |
| Mesh entity    : IP                                                |
| Last 3 Changes :  1.66743E+08  1.66743E+08  1.66743E+08            |
| Tolerance      :  1.0000E-02                                       |
| The Newton iteration was either slowly converging or has stalled.  |
| The solver will continue with the variable set as it was on the    |
| final iteration.  If this situation continues you might try        |
| increasing the number of iterations allowed for Newtons method.    |
| This can be changed by setting one of the parameters:              |
| Temperature : "Constitutive Relation Iteration Limit"              |
| Pressure    : "Newton Pressure Iteration Limit"                    |
| for your mixture using the definition file editor.
有大家不吝赐教!小弟先谢了!
发表于 2006-6-3 12:53:06 | 显示全部楼层
那你为什么不用fluent算呢,那里面的设置项更多,更细致。
cfx的例子中根本就没有涉及到超音速的,估计在这个方面的优势不大
