查看: 3269|回复: 1
[求助]cfx4.3如何安装?
发表于 2003-6-17 10:53:23 | 显示全部楼层 |阅读模式
我用的是winnt4。0
cfx4.3 for nt
不知是不是需要其他软件支持?
一点setup要么说是内存不够。要么demoshield不能用。
下面是文件的安装描述:
1) Run setup and install.
  2) Run the setup from the cfxlm dir and install.
  3) Copy the license.dat to the dir where you installed CFXlm
  4) Since this program is a linux port you will also need cygnus B20
     you can download this at http://sourceware.cygnus.com/cygwin/
Make sure you put the bin directory of cygnus in your path else the program
will not run.
Make sure you also have Exceed 6.1 and Exceed 3D 6.1 installed
For optimal use of this program you will also need interbase
you can download this at:
     http://www.interbase.com/open/downloads/ib_download.html
可是第一步都不行?
发表于 2003-7-31 18:29:46 | 显示全部楼层
[求助]cfx4.3如何安装?
我现在装cfx4.4遇到这个情况。
