查看: 5040|回复: 4
PLOT3D format
发表于 2002-6-1 09:14:25 | 显示全部楼层 |阅读模式
A lof of software accept the PLOT3D format, and  here it is a small introduction of plot3d format.
Grid Files
The grid file (XYZ file) defines the coordinates of the grid points in the structured mesh.  The points are stored in IJK order with all of the X components stored first, followed by the Y coordinates and the Z coordinates.  If the file contains IBlank information, it is stored after the Z coordinates.
XYZ Single Grid
READ(IUNIT) IDIM, JDIM, KDIM
READ(IUNIT) (((X(I,J,K), I=1,IDIM), J=1,JDIM),K=1,KDIM),
C                      (((Y(I,J,K), I=1,IDIM), J=1,JDIM),K=1,KDIM),
C                      (((Z(I,J,K), I=1,IDIM), J=1,JDIM),K=1,KDIM)
XYZ with IBlank
C                      (((Z(I,J,K), I=1,IDIM), J=1,JDIM),K=1,KDIM),
C                      (((IBLANK(I,J,K), I=1,IDIM), J=1,JDIM),K=1,KDIM)
2D XYZ File Single Grid
XYZ File with Multiple Grids
READ(IUNIT) NGRID
READ(IUNIT)  (IDIM(IGRID), JDIM(IGRID), KDIM(IGRID), IGRID=1,NGRID)
DO 10 IGRID=1,NGRID
READ(IUNIT)
C  (((X(I,J,K), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)),K=1,KDIM(IGRID)),
C  (((Y(I,J,K), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)),K=1,KDIM(IGRID)),
C  (((Z(I,J,K), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)),K=1,KDIM(IGRID))
10CONTINUE
XYZ File with Multiple Grids and IBlanks
READ(IUNIT) NGRID
DO 10 IGRID=1,NGRID
READ(IUNIT)
C  (((Z(I,J,K), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)),K=1,KDIM(IGRID)),
C  (((IBLANK(I,J,K), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)),K=1,KDIM(IGRID))
10CONTINUE
2D XYZ File Multiple Grid
READ(IUNIT) NGRID
READ(IUNIT)  (IDIM(IGRID), JDIM(IGRID), GRID=1,NGRID)
DO 10 IGRID=1,NGRID
READ(IUNIT)
10CONTINUE
Q Files
The Plot3D Q file contains flow quantities for the grid points defined in the XYZ file.  In order to properly use the Plot3D functions, the variables in the Q file must be properly normalized.  The free-stream density is assumed to be 1.  In other words, the Density (Q1) is assumed to have been divided by the free-stream density.  Similarly, the free-stream speed of sound is assumed to be 1.  Thus Momentum (Q2, Q3, Q4) must be normalized based upon these assumptions (it is assumed to have been divided by free-stream density and free-stream speed of sound).
The free-stream velocity magnitude is given by the free-stream mach number, FSMACH.  The direction of the free stream velocity is computed from the angle of attack, ALPHA (in degrees).   (The angle of attack is currently only used in the computation of the perturbation velocity vectors).
The other two constants:  RE and TIME are not currently used.
In computing the Plot3D functions, the fluid is assumed to be air and behave as a perfect gas.  The ratio of specific heats is assumed to be 1.4 and the gas constant is assumed to be 1.
Q File Single Grid
READ(IUNIT) IDIM,JDIM,KDIM
READ(IUNIT) FSMACH, ALPHA, RE, TIME
READ(IUNIT) ((((Q(I,J,K,NX), I=1,IDIM), J=1,JDIM), K=1,KDIM), NX=1,5)
2D Q File
READ(IUNIT) (((Q(I,J, NX), I=1,IDIM), J=1,JDIM), NX=1,4)
Q  File Multiple Grid
READ(IUNIT) NGRID
READ(IUNIT) (IDIM(IGRID),JDIM(IGRID),KDIM(IGRID), IGRID=1,NGRID)
DO 10 IGRID=1,NGRID
   READ(IUNIT) ((((Q(I,J,K,NX), I=1,IDIM(IGRID)), J=1,JDIM(IGRID)), K=1,KDIM(IGRID)), NX=1,5)
          10  CONTINUE
发表于 2002-12-5 14:36:10 | 显示全部楼层
PLOT3D format
***** 版主模式 *****
<a href=topic.cgi?forum=15&topic=3>该贴子已被管理员转移,请点击这里查看</a>
发表于 2007-12-3 10:04:58 | 显示全部楼层
PLOT3D format
好帖,百度了半天,就楼主的帖子关于plot3d格式的介绍最为详细,多谢!
发表于 2007-12-3 12:10:01 | 显示全部楼层
PLOT3D format
谢谢楼主的介绍,很详细。象网格生成软件Gridgen和后处理软件Tecplot,都有Plot3d格式的I/O
发表于 2011-6-11 15:56:41 | 显示全部楼层
回复 1# boling2000 的帖子
楼主,怎么用c语言读取plot3d(unformatted或者binary)网格数据呢?
