查看: 7029|回复: 2
CFX中移动网格计算中,出现网格负体积后怎么办?
发表于 2006-10-8 19:37:29 | 显示全部楼层 |阅读模式
急求帮助:
  我最近采用CFX计算物体在海水中做大位移运动,能成功进行计算,但是计算了3秒左右,就出现网格负体积,停止运算了,我知道应该重新对这种网格进行插值迭代,但是具体怎么操作,不清楚,请问各位高手,怎么进行二次计算,在原有的计算结果上进行?
出现的问题提示如下:
1。
| ERROR #002100012 has occurred in subroutine cVolSec.               |
| A negative element volume has been detected.  This is a fatal      |
| error and execution will be terminated.  The location of the first |
| negative volume is reported below.                                 |
|     Volume   :  -0.8873E+06                                        |
|     Location : (  0.27572E+12, -0.19221E+00,  0.11457E+00)         |
|                     ****** Notice ******                           |
|     1 flat tetrahedral elements have been detected in              |
| element set   1 of the domain                                      |
| AUVInTubeHalf.                                                     |
| The coordinates of one of the elements are                         |
| (  0.2154E+01,  0.5950E-02,  0.2665E-02 ).                         |
| If you experience robustness or accuracy problems, consider        |
| improving the mesh.                                                |
非常感谢各位的帮忙!
发表于 2006-10-27 11:32:56 | 显示全部楼层
大位移的你要改用fluent, 目前的CFX網格並非remesh,而是在某個程度內彼此拉扯,因此位移大到一定程度時就會出現如此fault code,看CFX11出來時是否會改善!
发表于 2006-11-22 13:23:33 | 显示全部楼层
画网格后有一个检查的步骤,我也出过负网格这种错误,改了好几天也不行,后来干脆重画一便就用一天就好了,你也试一试吧
