查看: 4355|回复: 0
计算 煤燃烧的 燃尽率 in CFX-post
发表于 2007-4-13 13:59:00 | 显示全部楼层 |阅读模式
Hi, I am working on coal combustion simulation using Lagrangian. The next step is to calculate Burnout, defined as (1-mfa0/mfa)/(1-mfao). When I introduce this into "Expression" in CFXPOST, an error information appears as
INTERNAL
[internal error detected:]
Number of values in retrieved variable does not match number of vertices
Burnout should be calculated based on track variables or field variables? Have anyone have such experience or knowledge?
I need your help urgently. Pls reply or contact me by (ben.simpsons@gmail.com). Thanks in advance.
Ben[color=#DC143C]文字[color=#A52A2A]文字
