查看: 3648|回复: 1
碰到这样的问题,如何设置专家参数?
发表于 2007-9-28 09:45:18 | 显示全部楼层 |阅读模式
Parallel run: Received message from slave
Slave partition :        2
Slave routine   : NEWT_FIT
Master location : BRCBUF,MSGTAG=1062
Message label   : 009100012
Message follows below - :
|                     ****** Notice ******                           |
| Newtons method failed to converge in  150 iterations.  This        |
| occurred while computing the following variable:                   |
| Variable Name  : Total Pressure                                    |
| Location Name  : fluid                                             |
| Mesh location  : VERTICES                                          |
| Mesh entity    :                                                   |
| Last 3 Changes :  3.04927E+04  3.18273E+04  3.06998E+04            |
| Tolerance      :  1.0000E+00                                       |
| The Newton iteration was diverging.  The solver will continue      |
| with the variable field as it was on the final iteration.  If      |
| this situation continues you might try decreasing the Netwon       |
| iteration under relaxation factor.  This can be changed by         |
| setting one of the following parameters:                           |
| Temperature : "Constitutive Relation Under Relaxation"             |
| Pressure    : "Newton Pressure Under Relaxation"                   |
| for your mixture using the definition file editor.                 |
 楼主| 发表于 2007-9-28 09:58:37 | 显示全部楼层
碰到这样的问题,如何设置专家参数?
声明:网格没有问题,计算理想气体时不会出现这样的问题,这个是在计算水蒸汽时产生的
专家参数中Relaxation Parameters有三个:
model coefficient relaxation
outer loop relaxation default
relax mass
问有没有这方面设置经验的,这三个参数如何设置?
如果不是这三个参数,如何解决计算中出现的问题?
