查看: 7127|回复: 18
[求助]谁成功地安装过ANSYS-CFX TASCFLOW-02.12.02?
发表于 2004-7-8 10:00:22 | 显示全部楼层 |阅读模式
   各位同行我安装了好几次ANSYS-CFX TASCFLOW-02.12.02,但都没有完全彻底成功,在CRACK文件中提示安装第四步是:Manually install flexlm services using the flexlm applet. Start Flexlm services.这一过程不知如何操作,望高手指导。Thanks in advanced!!!!
发表于 2004-7-8 13:36:47 | 显示全部楼层
i just made my own judgement during the process of installation and nothong wrong with it. you can just install the software first and then copy your license file into the designated directory and folder. that's it.
 楼主| 发表于 2004-7-16 09:59:41 | 显示全部楼层
   I had done that like you,But I can not open "start CFX-TASCflow GUI".I thought every thing would  be OK if install  Flexlm services .But how to
Manually install flexlm services using the flexlm applet.I do not know ,I need your help!!! Thanks in advanced!!!
发表于 2004-7-16 10:27:39 | 显示全部楼层
我也没有装成功,同问
发表于 2004-7-17 13:32:10 | 显示全部楼层
it should not be any big deal at all. i just followed the suggestions from the installation software itself and i made it. i can't exactually remember what steps are required to go through. but if you are asked to install license manager, you can choose solver/client and move on. you should be able to install it.
The problem with mine is that when i click on some buttons, the corresponding GUI did not pop up. i don't know for sure if this has somethign to do with requirement of installation of EXCEED and EXCEED 3D, which are supposed to be installed before tascflow can be installed.
if anyoney can figure this out, please post their procedure.
Thanks.
发表于 2004-8-26 23:57:35 | 显示全部楼层
我也出现了相同的问题,EXCEED装的是6.2版本,是否一定要7.1版本以上?不过我试过还是不行!
是不是有别的原因?
请指点!谢谢!
发表于 2004-11-7 18:52:43 | 显示全部楼层
我也遇到了同样的问题,焦急万分!!
请高手指点,多谢!!!
发表于 2004-11-15 11:33:33 | 显示全部楼层
必须要安装exceed3d的!!!
发表于 2004-12-12 12:43:37 | 显示全部楼层
我成功安装了,呵呵!
发表于 2004-12-13 15:10:22 | 显示全部楼层
請兄弟分享給大家參考一下,大家都非常想知道,
後面大家互相學習比較快
发表于 2004-12-27 10:33:24 | 显示全部楼层
必须安装exceed3d
发表于 2004-12-29 11:01:11 | 显示全部楼层
  各位成功安装了的高手,教 教 我们这些着急的人嘛.
发表于 2005-1-6 12:02:27 | 显示全部楼层
CFX5.7.1版本已出了,它不再需要安装Exceed
发表于 2005-1-10 16:51:13 | 显示全部楼层
请问CFX5.7.1哪有下的吗?
发表于 2006-11-17 17:13:46 | 显示全部楼层
我安装成功了,首先安装exceed&exceed3d,win2000安装exceed6.2,winxp安装exceed7.1以上版本,按照crack中的步骤安装好后,然后安装ansys licese flexlm manger,然后打开flexlm lmtools utility选择config servers来指定tascflow的lmgrd.exe和license.dat,Good luck
