查看: 2764|回复: 6
[求助]ANSYS.ICEM.CFD.FOR.CFX.V1.0-ISO安装的时候遇到问题!
发表于 2005-7-3 09:50:42 | 显示全部楼层 |阅读模式
1. Open the ansys.dat and change host to your computer name and 00000000000 to your
   hostid. Run the key.bat which will create a license.dat file.
2. Run setup and install ICEM CFD. Set the designation folder so there is no spaces
   in the path. Select to install all products. Chose a typical installations then
   select the additional Meshers and Vertical Applications.
3. At the end of the installation select to install the Ansys Licensing software.
   (Do not install the ICEM CFD Licensing software) When prompted point the browser
   to license.dat you created in step #1.
4. Set the license environment:
   ANSYSLMD_LICENSE_FILE = 1055@host  (Host being your computer name)
5. Reboot and run the program.
按照上述的安装英文安装帮助安装完毕后出现以下出错提示:
Error: can';t get a licence
 楼主| 发表于 2005-7-3 09:51:46 | 显示全部楼层
请大虾帮帮忙!
发表于 2005-7-8 20:11:49 | 显示全部楼层
Licensing.txt 没搞好 请问用ANSYS几的版本?
 楼主| 发表于 2005-7-9 23:23:28 | 显示全部楼层
版本为  ICEM CFD 4.CFX
使用安装盘里附带的licence生成器生成的licence,生成的licence文件的后缀为.dat
 楼主| 发表于 2005-7-11 10:37:37 | 显示全部楼层
我使用下面的crack生成的licence,并且按照里面的说明进行的安装,可还是不能用。
请大虾帮忙啊!
 楼主| 发表于 2005-7-12 10:35:29 | 显示全部楼层
非常希望大虾的帮助!
 楼主| 发表于 2005-7-15 09:05:32 | 显示全部楼层
斑竹不经常上网么?
