查看: 2665|回复: 1
gridgen新手问题.
发表于 2006-9-29 09:04:11 | 显示全部楼层 |阅读模式
用gridgen划网格的时候,里面有很多DOMS,怎样合并这些DOMS??
同一个面可能存在2个DOMS.
另外,CONS 有的没有用到,但是因为跟其他DOMS上的CONS在一起分辨不出来,不好删除.
这些没有用到的CONS,对以后的计算有影响吗?(FLUENT)
发表于 2006-11-27 03:27:34 | 显示全部楼层
gridgen新手问题.
no way, just delete.
It is not allowed to have two overlapping structured domain at the same position, but it is ok for unstructured domains.
delete all the unused connectors, or it can not be exported into fluent.
use display-unable blocks to find and delete them.
