查看: 2706|回复: 0
[求助]请教Cart3D一个问题?
发表于 2007-3-19 16:30:20 | 显示全部楼层 |阅读模式
我按照ICEUM Cart3D中supersonic missile 那个例子做到能够用Preview Mesh only显示弹体的计算网格了,但是切换到Create and Save Full Mesh保持网格时就出错了,最后一部分的提示是:
   O--------------- Mesh Information -------------------------O
   | Final number of     hex cells  is:    260940             |
   | Final number of hex cell faces is:    805720             |
   | Final number of cut hex cells  is:    14149              |
   | Total number of surf triangles is:    9500               |
   | # adt/non-adt  spanner lookups is:    23 / 938208        |
   O----------------------------------------------------------O
Application is finished.
Error: Cart3D Mesher Did not create the mesh
是不是我机子的内存不够,还是其它原因?
