查看: 9113|回复: 11
tecplot画出的流线为什么有断截的情况?
发表于 2008-4-3 11:53:03 | 显示全部楼层 |阅读模式
tecplot画出的流线为什么有断截的情况?请高手给指点一下,谢谢![br][br][以下内容由 qx0991 在 2008年04月08日 11:00am 时添加] [br]
为什么我的问题没人回答呢?
 楼主| 发表于 2008-4-10 13:53:43 | 显示全部楼层
我好像有点明白了,谢谢拉!另外还有个问题,你知道关于时间步长的设置吗?怎么确定合适的时间步长呢?什么时候可以改大时间步长?
回复 支持 1 反对 0
使用道具 举报
发表于 2008-4-8 13:52:48 | 显示全部楼层
你最好给张图,大家好帮你分析。我猜测有可能是因为流线是三维的,而你选的是一个二维面
 楼主| 发表于 2008-4-8 16:13:11 | 显示全部楼层
这个就是流线的情况,按理说流线应该是从头到为都有的,这个流线是车身顶部外流场的流线,是对称面上的,应该是从头到位挺长的一段,可是拉一条线只有这么长一段,我是想是不是有什么地方设置流线的长度,每画一笔都很短!有没有一笔画过去就是从头到位都有的。
发表于 2008-4-9 18:27:39 | 显示全部楼层
要更改流线中的步长设置,step
发表于 2008-4-9 18:29:56 | 显示全部楼层
Streamtrace Details > Integration > step size / Max steps
 楼主| 发表于 2008-4-10 09:28:53 | 显示全部楼层
我试试看,谢谢了!
 楼主| 发表于 2008-4-10 09:35:32 | 显示全部楼层
lioncfd :我试了,还试不行,具体怎么设步长的数值呢?
发表于 2008-4-10 12:12:10 | 显示全部楼层
•  Step Size - Enter the initial and maximum step size Tecplot uses while inte­grating through the vector field, as a decimal fraction of the local cell or ele­ment width. A typical value (and the default) is 0.25, which results in four integration steps through each cell or element. The value for Step Size affects the accuracy of the integration. Setting Step Size too small can result in round-off errors, while setting it too large can result in truncation errors and missed cells.
•  Max Steps - Enter the maximum number of steps before the streamtrace is ter­minated. This prevents streamtraces from spinning forever in a vortex, or from wandering aimlessly in a region where the vector components are very small, very random, or both. If you choose a small Step Size, you should enter a larger Max Steps.
•  Minimum Step Size - The smallest step size for Tecplot to use. Setting this too small results in integration problems. Setting this greater than or equal to the Step Size results in a constant step size.
•  Obey Source Blanking - When active, streamtraces are generated for non-blanked regions only. When inactive, streamtraces are generated for blanked and unblanked regions.
发表于 2008-4-10 12:18:58 | 显示全部楼层
这是Tecplot自带的一个例子
发表于 2008-4-10 12:25:50 | 显示全部楼层
更改Max steps 流线会发生变化
发表于 2008-4-10 12:32:57 | 显示全部楼层
我觉得你可以增大 Max steps 的值,比如改成2000或3000试试
