查看: 3478|回复: 1
[讨论]TECPLOT9中如何有选择地显示网格
发表于 2003-3-31 16:09:11 | 显示全部楼层 |阅读模式
因为GAMBIT的网格太密了,想隔几个网格显示一次,但网格属性里面没有相应的选项,怎么解决?谢谢!
发表于 2003-4-12 03:02:54 | 显示全部楼层
If it is  IJK-volume grid, you can double click the grid, and in the popuped dialog, select the Volume tab, then choose:
Range I-Planes,  Range J-Planes,  Range K-Planes,
fill the three editboxs: start-end-Skip
OK?
