查看: 2785|回复: 6
[求助]在tecplot中如何生成等值线?
发表于 2004-6-11 15:33:43 | 显示全部楼层 |阅读模式
在tecplot中如何生成等值线?
发表于 2004-6-11 15:39:54 | 显示全部楼层
field-contour attributes-contour plot type-lines
 楼主| 发表于 2004-6-11 20:19:18 | 显示全部楼层
没有这些菜单选项呀?我用得是10.0
发表于 2004-6-11 21:49:14 | 显示全部楼层
TITLE = "Example: Multi-Zone 2D Plot"
VARIABLES = "X", "Y"
ZONE T="BIG ZONE", I=41, J=11, F=POINT(i,j ,你自己定)
如果你的数据保存在。tex文件里
那么加入上面的语句
然后在tecplot中load date(file)就可以了
 楼主| 发表于 2004-6-12 15:35:33 | 显示全部楼层
我是这样写的(其中有多个变量,有限元数据):
TITLE="GACIM"
VARIABLES="X", "Y", "", "F", "VISCOS", "U_X", "U_Y", "T"
ZONE F=FEPOINT,  ET=TRIANGLE,  N= 407     E= 738
可以显示各变量的contour图像,就是不知如何显示等值线?
发表于 2004-6-12 23:57:30 | 显示全部楼层
I also use TECPLOT10.
After you make contour plot, go to 'Zone Style...' which locates in middle left, choose contour in the Zone Style window, and then change contour type from flood to lines. Good luck!
 楼主| 发表于 2004-6-13 16:12:04 | 显示全部楼层
That's great! Thank you a lot!
