查看: 3283|回复: 5
Please help! How to get symmetry mesh for this model?
发表于 2003-6-7 09:28:07 | 显示全部楼层 |阅读模式
发表于 2003-6-7 17:28:08 | 显示全部楼层
你能不能放一个SAT文件,你的图看不清楚。
 楼主| 发表于 2003-6-8 00:03:27 | 显示全部楼层
the chamber dimension is:
2in length, 2in Diameter
The nozzle length is 0.5in.
The nozzle outlet diameter is 0.708in.
There are four tengential inlets (0.111in diameter each) near the bottom!
Their center just 0.125in up the bottom.
And there are four radial inlets (0.102in diameter each)from the head end.
Their center just 0.125in below the head end.
And one secondary inlet (0.111in diameter) from the center of head end.
Thanks a lot!!!!
发表于 2003-6-9 09:59:42 | 显示全部楼层
老大,你想在那里作网格?
如果是此图的对成面网格,你可以做半模,去建网格,做流场计算!
 楼主| 发表于 2003-6-12 05:44:42 | 显示全部楼层
but it is not symmetry!!
I do not know how to decompose this geometry?
发表于 2003-6-12 10:06:00 | 显示全部楼层
可以直接在Fluent中切取对称面网格和流场
