查看: 3022|回复: 1
[求助]动网格时提示有些单元是0体积怎么办?
发表于 2004-11-28 11:05:55 | 显示全部楼层 |阅读模式
[这个贴子最后由alpinist在 2004/11/28 11:09am 第 1 次编辑]
搞动网格的遇到过没有这种问题?怎么解决啊,谢谢!!
如下:
**ERROR - THERE ARE     560 ACTIVE CELLS WITH ZERO VOLUME
**ERROR LOADING EVENT NUMBER      48. PLEASE CHECK THE GRID C
 楼主| 发表于 2004-12-1 09:29:36 | 显示全部楼层
这是提示,高手帮忙看看,谢谢了!
uparm.f:
Parsing uparm                          :      56
    Generating Intermediate Code       :      54
ibe.exe -N31 -N104 -N2 -N101 +N19 -O -o "uparm.obj" -i "C:\DOCUME~1\ADMINI~1\LOC
ALS~1\Temp\Abs64_uparm.int"
del C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Abs64_uparm.int
f77 -f -v -N26 -N3 -N25 -Q101 +Q19 -O starin.obj star_main.obj formula.obj ufile
/uparm.obj dummy_sp.obj cdlmgrc.lib libstar.a libusr.a libamgdum.a libgtpd.a vms
.lib unix.lib wsock32.lib advapi32.lib -aliases:unicode.als -o star.exe
lnk.exe "@star.amh"
d:/progra~1/cd-ada~1/star-c~1/wingnu/bin/basename.exe: too few arguments
Try `d:/progra~1/cd-ada~1/star-c~1/wingnu/bin/basename.exe --help'; for more info
rmation.
D:/PROGRA~1/CD-ADA~1/STAR-C~1/bin/starlink[725]: [: keyboard: unexpected operato
r/operand
r/operand
d:/progra~1/cd-ada~1/star-c~1/wingnu/bin/mv: preserving times for uparm.f: Input
or output error (EIO)
F:\STARCD~1\TRANSI~1\3D-NEW~1.27>pause
Press any key to continue . . .
