查看: 2161|回复: 2
question about remeshing
发表于 2005-7-28 03:05:45 | 显示全部楼层 |阅读模式
first please excuse me for not being able to input in chinese.
I am now using the es-aero tool to generate volume meshes for the external flow around a car surface, and everytime after the mesh generation is finished, there are several cells that failed negative volume, zero face area or tetrahedral quality check. As for negative volume cells, I used the cflip command, but it seemed that the problem still existed. Now, I am considering remeshing the neighbor volume around the negative volume cells or other cells and then matching(coupling) new meshes back with old ones. Does anyone in here know the commands/GUI operations to do this? Thanks in advance.
发表于 2005-7-29 11:25:35 | 显示全部楼层
对于少量不能使用的网格可以采用手动修复,在Pro-am和es-aero中都有这种修复功能。
如果产生大量不能使用的网格,那最好是重新划分!
发表于 2005-7-29 13:56:25 | 显示全部楼层
only some error mesh can';t run
Please delete these mesh, just seem it';s the resistance and some error.
It';s no to remesh it.
