查看: 4689|回复: 7
这是什么错误?
发表于 2002-12-9 20:55:13 | 显示全部楼层 |阅读模式
error : too many streamline to scan?
那位兄弟指点一下?
 楼主| 发表于 2002-12-9 21:31:52 | 显示全部楼层
这是什么错误?
写错了,是:too many fields to scan
发表于 2002-12-10 20:04:23 | 显示全部楼层
这是什么错误?
是numeca里面的错误么?
哪个模块出现的?
 楼主| 发表于 2002-12-10 22:50:45 | 显示全部楼层
这是什么错误?
在autogrid模块,不知道是不是盗版的原因,嘿嘿
发表于 2002-12-11 10:12:25 | 显示全部楼层
这是什么错误?
你用的是盗版?
是在生成网格的时候?
还是在生成网格前的参数调整时?
发表于 2002-12-11 16:50:51 | 显示全部楼层
这是什么错误?
厉害,怎么盗版的?倒想请教!
 楼主| 发表于 2002-12-11 23:39:47 | 显示全部楼层
这是什么错误?
do you feel strange? I am a poor student ? do you think i can offer for so expensive soft?as you see , if it is very good after i try it , maybe I will suggest my boss buy it thought i can not offer it!
  the error if just in aotugrid , when i finished setup the geometry and topo .. I click the next botton , it tell me ; too many fields to scan
   by the way , I am use fine/turno 6.0 , but the example is 5.2 , but I think it will not be the case , so may be you I have a 6.0 case , give one to me , 3x
发表于 2002-12-12 13:41:27 | 显示全部楼层
这是什么错误?
it should not be wrong using diffirent version cases.
you can try to reduce the number of the grid
and the newest version of numeca is 5.3.
I want to know how do you get the version of 6.0?
