查看: 3133|回复: 0
[公告]Call For Papers of FIV2008
发表于 2006-12-10 20:07:36 | 显示全部楼层 |阅读模式
SCIENTIFIC AND TECHNICAL TOPICS SCIENTIFIC AND TECHNICAL TOPICS
The conference will be focused on the theoretical, computational and experimental approaches  of flow-induced vibrations including, but not limited to: The conference will be focused on the theoretical, computational and experimental approaches  of flow-induced vibrations including, but not limited to:
• Advances in fluid-structure interaction theory  • Advances in fluid-structure interaction theory
• Computational methods in flow-induced vibrations  • Computational methods in flow-induced vibrations
• Fluid-structure interaction in biomechanics  • Fluid-structure interaction in biomechanics
• Active and passive control of flow-induced vibration  • Active and passive control of flow-induced vibration
• Signal processing techniques used in flow-induced vibration studies  • Signal processing techniques used in flow-induced vibration studies
• Vibration of heat exchanger tube arrays to cross or axial flow  • Vibration of heat exchanger tube arrays to cross or axial flow
• Vibration of ship and offshore structures  • Vibration of ship and offshore structures
• Thin-walled structures in flow  • Thin-walled structures in flow
• Sloshing and flexible containers  • Sloshing and flexible containers
• Vibration of underwater cables and risers  • Vibration of underwater cables and risers
• Vibration resulting from cavitation and turbulence  • Vibration resulting from cavitation and turbulence
• Wing and helicopter aeroelasticity  • Wing and helicopter aeroelasticity
• Vibration of valves and piping systems  • Vibration of valves and piping systems
• Vibration of hydraulic gates and turbines  • Vibration of hydraulic gates and turbines
• Flow-induced vibration in two phase flows  • Flow-induced vibration in two phase flows
• Wind induced vibration of buildings and structures  • Wind induced vibration of buildings and structures
• Vibration problems involving flow-acoustic coupling  • Vibration problems involving flow-acoustic coupling
• Flow-induced vibration in musical instruments and vibroacoustics • Flow-induced vibration in musical instruments and vibroacoustics
Organized by Organized by
Institute of Thermomechanics Institute of Thermomechanics
Academy of Sciences of the Czech Republic Academy of Sciences of the Czech Republic
