查看: 3341|回复: 4
关于假扩散
发表于 2003-3-14 02:33:54 | 显示全部楼层 |阅读模式
有没有高手在这方面有研究的。请指给我一条明路!!!!
发表于 2003-3-27 19:45:42 | 显示全部楼层
关于假扩散
请看帕坦卡的“传热与流体流动的数值计算“一书。
发表于 2003-9-5 22:39:02 | 显示全部楼层
关于假扩散
TAO WEN QUAN's book ---computational heat tranfer-- also has many discussion on it.
发表于 2003-9-5 23:43:02 | 显示全部楼层
关于假扩散
假扩散 is caused by the differentiational scheme. If you use the central difference sheme(CDS), you will not have that problem(but you should set much denser grids to provent oscillatory results).
发表于 2003-9-25 21:37:39 | 显示全部楼层
关于假扩散
sometime 假扩散 is useful as 'artificial viscosity', and used to eliminate oscillation of computational results, especially for shock problem.
