查看: 2541|回复: 0
Free Convection in a Water Glass
发表于 2004-5-24 00:28:03 | 显示全部楼层 |阅读模式
[这个贴子最后由femlab在 2004/05/24 00:32am 第 1 次编辑]
http://www.femlab.com.cn/democd/html/195.html
This model treats the free convection and heat transfer of a glass of cold water heated at room temperature. The flow is modeled with the application mode for non-isothermal flow and the temperature field using the convection and conduction application mode in the chemical engineering module. Initially, the glass and the water holds 5 °C (brought out from a refrigerator). It is then put on a table in a room at 25 °C.
登录/注册后可看大图
Streamlines of the velocity field at four output times. The buoyancy driven flow induces recirculation zones visualized by the streamlines in the figure.
