查看: 2801|回复: 1
Flow against a deformable body
发表于 2003-10-9 09:58:06 | 显示全部楼层 |阅读模式
This example shows the flow through a valve. The valve is partly closed by an elastic membrane. The increasing pressure in the inlet of the tube increases the velocity. This causes an ascending dynamic pressure on the membrane. The membrane deforms more and more and closes the valve.
发表于 2004-5-15 18:23:16 | 显示全部楼层
我是初学者。可不可以告诉我怎么作出来的吗?
