查看: 5899|回复: 11
[下载]用非结构重叠网格计算昆虫拍翼的文章
发表于 2003-12-29 19:13:02 | 显示全部楼层 |阅读模式
FLOW SIMULATION OF FLAPPING WINGS OF AN INSECT USING OVERSET UNSTRUCTURED GRID
AIAA-2001-2619
Flow over a hornet in forward flight is numerically simulated by solving the Navier-Stokes equations. ^The complex configuration of a hornet, including antennas, legs, and sting, are realistically reconstructed in the computational space by an unstructured grid. ^The flapping wings are treated by the overset unstructured grid method, where an unstructured grid around the wing is overlapped on a stationary grid around the body of the hornet and moves in time to simulate the flapping motion. ^To improve the accuracy of interpolation between grids, a mesh refinement method was adopted to enforce mesh sizes similar at the intergrid boundary regions. ^In this paper, the capability of the overset unstructured grid method is demonstrated and discussed. ^(Author)
 楼主| 发表于 2003-12-29 19:14:42 | 显示全部楼层
这是第二部分。全部解压后,允许合并程序就可以得到一个完整的rar压缩文件。再解压就得到原文件(pdf格式的)。
发表于 2003-12-29 22:51:31 | 显示全部楼层
谢谢,iceArcher兄弟,我下了,很好的文章,不知道iceArcher的方向是什么,希望多读交流噢
 楼主| 发表于 2003-12-31 09:35:02 | 显示全部楼层
呵呵,我的研究方向是重叠网格技术,对仿生不懂的,还要向各位高人请教呢。。我只是在平时查阅文献时看到大家可能感兴趣的文章就贴过来了,希望能有点帮助而已。
发表于 2003-12-31 13:18:28 | 显示全部楼层
谢谢
发表于 2003-12-31 21:21:49 | 显示全部楼层
谢谢
发表于 2004-1-1 22:10:20 | 显示全部楼层
liyijin,你是那里的,搞什么方向,希望多交流
发表于 2004-8-10 15:17:45 | 显示全部楼层
我怎么看不到?
发表于 2005-4-20 20:36:18 | 显示全部楼层
好东西
发表于 2005-11-23 10:07:40 | 显示全部楼层
怎么看不到
发表于 2005-11-23 11:07:53 | 显示全部楼层
part1
发表于 2005-11-23 11:09:26 | 显示全部楼层
part2
