查看: 3971|回复: 2
请教一个英语翻译!谢谢
发表于 2008-6-27 10:02:12 | 显示全部楼层 |阅读模式
unphysical currents near the interfaces
该如何翻译呢?是交界面附近的非物理流量?还是什么别的?
谢谢了
全句是:
The perturbation step involving the color redistribution function results in artificial anisotropic surface tension that induces unphysical currents near the interfaces.
发表于 2009-3-5 00:34:07 | 显示全部楼层
回复 1# waterrock 的帖子
Are you using the Level set method or VOF method to track the two phase flow? I absolutely do not know how to transfer it into Chinese, but I have met this problem before.
从数值计算的角度讲,应该翻译成“界面处的伪(动量)通量”,仅供参考。
        BY  PETER_UMASS
发表于 2009-3-10 16:19:46 | 显示全部楼层
看帖~顶帖是美德!
登录/注册后可看大图
秃驴,敢跟贫道抢师太?
桔色光宇no5时尚广场游易梦芭莎
