查看: 3873|回复: 7
[原创]代数网格超限插值2D/3D模块
发表于 2003-9-30 14:23:56 | 显示全部楼层 |阅读模式
这是先前需要自己编程序作网格时写的代码。它主要是将物理空间的面(2D)或体(3D)转换到参数空间后进行超限插值计算,得到中间各个点的坐标值,其中U,V,W表示网格点的X,Y,Z数组。
实际应用时,必须先生成网格的边界。该程序的理论依据好像是Soni(?)提出的,具体的公式嘛,哈哈,忘了,能查到的(就是太麻烦-_-!)。
      SUBROUTINE SONITFI ( U,V,IM,JM,IERR )
      IMPLICIT NONE
      INTEGER IM,JM,I,II,J,JJ,IERR
      REAL ETA,XSI,PLM,SX,SY,S1,S2,SM1,SM2,SL1,SL2
      REAL,DIMENSION(IM,JM):: U,V,ALM,BLM,CLM,DLM
      REAL,DIMENSION(IM):: GLM1,GLM2
      REAL,DIMENSION(JM):: HL1M,HL2M
      IERR = 0
      SM1  = 0.0
      SM2  = 0.0
      SL1  = 0.0
      SL2  = 0.0
      DO I = 2, IM
         SX  = U(I,1) - U(I-1,1)
         SY  = V(I,1) - V(I-1,1)
         SM1 = SQRT( SX * SX + SY * SY ) + SM1
         SX  = U(I,JM) - U(I-1,JM)
         SY  = V(I,JM) - V(I-1,JM)
         SM2 = SQRT( SX * SX + SY * SY ) + SM2
      ENDDO
      DO J = 2, JM
         SX  = U(1,J) - U(1,J-1)
         SY  = V(1,J) - V(1,J-1)
         SL1 = SQRT( SX * SX + SY * SY ) + SL1
         SX  = U(IM,J) - U(IM,J-1)
         SY  = V(IM,J) - V(IM,J-1)
         SL2 = SQRT( SX * SX + SY * SY ) + SL2
      ENDDO
      IF ( SM1 <= 0.0 .OR. SM2 <= 0.0 .OR.  &
           SL1 <= 0.0 .OR. SL2 <= 0.0 ) GOTO 999
      DO I = 1, IM
         S1 = 0.0
         S2 = 0.0
         DO II = 2, I
            SX = U(II,1) - U(II-1,1)
            SY = V(II,1) - V(II-1,1)
            S1 = SQRT( SX * SX + SY * SY ) + S1
            SX = U(II,JM) - U(II-1,JM)
            SY = V(II,JM) - V(II-1,JM)
            S2 = SQRT( SX * SX + SY * SY ) + S2
         ENDDO
         GLM1(I) = S1 / SM1
         GLM2(I) = S2 / SM2
      ENDDO
      DO J = 1, JM
         S1 = 0.0
         S2 = 0.0
         DO JJ = 2, J
            SX = U(1,JJ) - U(1,JJ-1)
            SY = V(1,JJ) - V(1,JJ-1)
            SX = U(IM,JJ) - U(IM,JJ-1)
            SY = V(IM,JJ) - V(IM,JJ-1)
         ENDDO
         HL1M(J) = S1 / SL1
         HL2M(J) = S2 / SL2
      ENDDO
      DO I = 1, IM
      DO J = 1, JM
         PLM = 1 - ( GLM2(I) - GLM1(I) ) * ( HL2M(J) - HL1M(J) )
         IF ( PLM == 0.0 ) GOTO 999
         XSI = ( GLM1(I) + HL1M(J) * ( GLM2(I) - GLM1(I) ) ) / PLM
         ETA = ( HL1M(J) + GLM1(I) * ( HL2M(J) - HL1M(J) ) ) / PLM
         ALM(I,J) = 1.0 - ETA
         BLM(I,J) = ETA
         CLM(I,J) = 1.0 - XSI
         DLM(I,J) = XSI
      ENDDO
      ENDDO
      DO I = 1, IM
      DO J = 1, JM
         U(I,J) = ALM(I,J) * U(I,1) + BLM(I,J) * U(I,JM) +  &
                  CLM(I,J) * U(1,J) + DLM(I,J) * U(IM,J) -  &
                  ALM(I,J) * CLM(I,J) * U(1,1)  -  &
                  BLM(I,J) * CLM(I,J) * U(1,JM) -  &
                  ALM(I,J) * DLM(I,J) * U(IM,1) -  &
                  BLM(I,J) * DLM(I,J) * U(IM,JM)
         V(I,J) = ALM(I,J) * V(I,1) + BLM(I,J) * V(I,JM) +  &
                  CLM(I,J) * V(1,J) + DLM(I,J) * V(IM,J) -  &
                  ALM(I,J) * CLM(I,J) * V(1,1)  -  &
                  BLM(I,J) * CLM(I,J) * V(1,JM) -  &
                  ALM(I,J) * DLM(I,J) * V(IM,1) -  &
                  BLM(I,J) * DLM(I,J) * V(IM,JM)
      ENDDO
      ENDDO
      GOTO 1000
999   IERR = 1
      WRITE(*,*)'ZERO VALUE ERROR!'
1000  RETURN
      END SUBROUTINE SONITFI
      SUBROUTINE SONITFI2 ( U,V,W,IM,JM,IERR )
      IMPLICIT NONE
      REAL ETA,XSI,PLM,SX,SY,SZ,S1,S2,SM1,SM2,SL1,SL2
      REAL,DIMENSION(IM,JM):: U,V,W,ALM,BLM,CLM,DLM
      IERR = 0
      SM1  = 0.0
      SM2  = 0.0
      SL1  = 0.0
      SL2  = 0.0
      DO I = 2, IM
         SZ  = W(I,1) - W(I-1,1)
         SM1 = SQRT( SX * SX + SY * SY + SZ * SZ ) + SM1
         SZ  = W(I,JM) - W(I-1,JM)
         SM2 = SQRT( SX * SX + SY * SY + SZ * SZ ) + SM2
      ENDDO
      DO J = 2, JM
         SZ  = W(1,J) - W(1,J-1)
         SL1 = SQRT( SX * SX + SY * SY + SZ * SZ ) + SL1
         SZ  = W(IM,J) - W(IM,J-1)
         SL2 = SQRT( SX * SX + SY * SY + SZ * SZ ) + SL2
      ENDDO
      DO I = 1, IM
         S1 = 0.0
         S2 = 0.0
         DO II = 2, I
            SZ = W(II,1) - W(II-1,1)
            S1 = SQRT( SX * SX + SY * SY + SZ * SZ ) + S1
            SZ = W(II,JM) - W(II-1,JM)
            S2 = SQRT( SX * SX + SY * SY + SZ * SZ ) + S2
         ENDDO
         GLM1(I) = S1 / SM1
         GLM2(I) = S2 / SM2
      ENDDO
      DO J = 1, JM
         S1 = 0.0
         S2 = 0.0
         DO JJ = 2, J
            SZ = W(1,JJ) - W(1,JJ-1)
            SZ = W(IM,JJ) - W(IM,JJ-1)
         ENDDO
         HL1M(J) = S1 / SL1
         HL2M(J) = S2 / SL2
      ENDDO
      DO I = 1, IM
      DO J = 1, JM
         BLM(I,J) = ETA
         DLM(I,J) = XSI
      ENDDO
      ENDDO
      DO I = 1, IM
      DO J = 1, JM
         W(I,J) = ALM(I,J) * W(I,1) + BLM(I,J) * W(I,JM) +  &
                  CLM(I,J) * W(1,J) + DLM(I,J) * W(IM,J) -  &
                  ALM(I,J) * CLM(I,J) * W(1,1)  -  &
                  BLM(I,J) * CLM(I,J) * W(1,JM) -  &
                  ALM(I,J) * DLM(I,J) * W(IM,1) -  &
                  BLM(I,J) * DLM(I,J) * W(IM,JM)
      ENDDO
      ENDDO
      GOTO 1000
999   IERR = 1
1000  RETURN
      END SUBROUTINE SONITFI2
发表于 2003-12-9 14:24:56 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
最好有变量说明呀
发表于 2003-12-13 22:04:47 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
能否贴出文献共享
 楼主| 发表于 2003-12-15 10:56:13 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
参看 William T.Jones,etc. "A GRID GENERATION SYSTEM FOR MULTI-DISCIPLINARY DESIGN OPTIMIZATION" AIAA-95-1689
发表于 2004-2-1 20:58:55 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
楼主说的超限插值就是无限插值法,公式很简单,数值传热学(陶文铨)上面有
发表于 2004-2-21 20:37:22 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
是否transfinite interpolation, 有些人译为无限插值
发表于 2004-2-21 21:48:28 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
我觉得就是
发表于 2004-2-27 22:21:11 | 显示全部楼层
[原创]代数网格超限插值2D/3D模块
作者能解释一下变量的意思吗
