查看: 2914|回复: 0
就业机会
发表于 2005-8-18 13:39:23 | 显示全部楼层 |阅读模式
In order to make the best use of all possible resources, ASDC HR would like to extend the invitation to all staff for recommendation of suitable candidates for the open position  as followed. Pls e-mail to Jennifer Luo at mailto:jzluo@trane.com if you had candidates who fits into the requirement published. Thanks.
1.1.       System Design Engineer 系统设计工程师
Job Responsibility
•• Coordination of a team of Electrical, Analysis and Mechanical engineers and Technicians for the development of new product from conception to manufacture
•• Develop major components for specific projects in air conditioning
•• Develop control logic and test plan
•• Test and qualify part and prototypes of the overall unit
•• Provide technical data for catalogues and engineering specifications
•• Continue analysis of competitors data
       Job Requirement
••         BS or Master degree in Mechanical Engineering with emphasis in Thermodynamics, heat Transfer and refrigeration.
••         At least 4 years experience of Chiller, Heat Pump, Rooftop and other air conditioning system design
••         Good PC skill
••        English written, spoken and reading mandatory
2.2.       Heat Transfer Design Engineer 传热工程师
Job Responsibility
••         Heat Transfer model for heat exchanger.
••         Develop new or improve existing heat exchanger
••         Performs engineering analysis required to verify design performance and reliability.
••         Materials specification
••         Prototypes and mock-up testing
••         Technical Data generation
       Job Requirement
••         BS or Master degree in Mechanical Engineering with emphasis in thermodynamics and  heat transfer.
••         2 to 5 years experience; a new graduate with applicable experience will be considered.
••         Demonstrated competency in at least one area of heat transfer or thermal systems design.
••         Familiarity with the design process for heat exchangers and refrigeration systems.
••         Working knowledge in heat exchanger design as well as Dynamic Test Instrumentation.
••         Overall knowledge of Machinery Standards, specifically air conditioning standards as ASHRAE, ARI, JIT, as well as Pressure Vessel Codes: ASME, PED
••         Excellent verbal and written communication skills and ability to work in a team environment required.
••         Good English and computer skills
3.3.       Electrical Engineer --Electronics
Job Responsibility
••         Contribute to development of requirements and specifications for new electrical and electronic products and components
••         Lead New Component Introduction (NCI) activities of the New Product Introduction process (NPI).
••         Work with suppliers to ensure that specifications and requirements are understood and being met.
••         Ensure successful implementation of new electrical and electronic products and components.
••         Identification and qualification of new suppliers
     Job Requirement
••         BSEE required
••         2-5 years experience in electronic design/development from concept through production of electrical systems, printed circuit boards, thermostats etc
••         Electronic qualification and test experience preferred.
••         Electronic PCB assembly manufacturing and test support experience desired.
••         Six Sigma training as a green belt or black belt required, certification preferred
••         Communicating controls (protocol) and wireless communications knowledge is a plus
••         HVAC or refrigeration systems and Indoor Air Qualify knowledge desired.
••         PC based Windows programs (Excel, Word, Access, PowerPoint, etc.)
••         Familiarity with agency and code requirements: UL
••         Good written and verbal communication skills
••         Problem assessment and problem solving skills
••         Good organizational skills
••         Results oriented.
••         Self starter
••         Strong team player
4.4.       Electrical Engineer—Low voltage electrical
    Job Responsibility
••         Design new starter panels for low and medium voltage under UL and CE certification standards
••         Select electrical and electromechanical components  for new units.
••         Write method description and procedure of testing for control system, starter and control panels.
••         Integrate software with hardware, test and verify the product functions.
••         Upgrade features to existing control system, starter and control panels.
••         Provide schematics for power and control wiring diagrams to support the elaboration of details and general assembly drawings.
••         Work with the team to validate overall control performance.
     Job Requirement
••         BSEE required
••         2 to 5 years experience in electrical design under six sigma environment; a new graduate with applicable experience will be considered.
••         Water chiller control knowledge a plus
••         Familiar with commonly used office software’s applications.
••         Proficient in use of electronic test equipment; supervision of electronics technicians
••         Overall knowledge of electrical standards UL and CE.
••         Ability to communicate effectively with others both written and orally.
••         Ability to function in a team environment.
••         Ability to travel independently 20-40%
5.5.       System Software Engineer
Job Responsibility
••         Design the software structure according to the requirements and specifications for intelligent control system
••         Programming and verify software with the software engineering method
••         Develop PC_based or/and embedded software for intelligent control system
••         Work with the team including hardware part  to validate overall system  performance
     Job Requirement
••         BSEE or MSEE
••         2++ years research or engineering experience in PC_based or/and embedded software Programming, debugging.
••         Familiar with C/C++ language and other software tools
••         Experience on MCU_based electronic circuit board design preferred.
••         Self starter
6.  Detailed Mechanical Designer 机械结构设计员
Job Responsibility
•Maintenance, upgrade, and enhancements of existing air conditioning products
•Selection and specification of mechanical and electrical components
•Work from oral instructions, written procedures, schematics drawings and ideas from himself and other team members
•Ensures all product design meet company standards, specially those related to safety, quality and reliability
&#8226articipation in the construction of prototypes
Job Requirement
•At least 2 years experience in mechanical design
•Use of all Microsoft friendly software’s, familiar with commonly use office software application and customization tools.
     Especially with AutoCAD , Mechanical Desktop ,Pro-E, Inventor  etc.
• Must be customer driven and quality minded in performance of all assigned duties.
• Knowledge and experience in assigned areas: materials and components selection, detailed mechanical design, fabrication, sheet metal, GD&T and tolerance analysis, piping, welding and casting.
•Ability to communicate effectively with others both written and orally
7.Testing Engineer (Electrical and Instrument Engineer) 仪器仪表及电器工程师
工作地点: 太仓(特灵空调亚洲实验中心) 办公室: 太仓
Job Responsibility
••         负责所有测试台仪器仪表的采购安装连接及定期标定
••         负责与美国联络确保数据采集系统的正常工作并及时升级
••         熟悉测试设备的控制逻辑
••         建立并管理实验室数据管理系统
Job Requirement
••         自动控制,仪器仪表,测量专业本科毕业
••         良好的英语听说读写能力
••         熟练使用VB编程
••        有工作经验者更佳
••         能承受工作压力,有责任心
••         能独立领导并完成项目
8.实验室技师
工作地点:太仓(特灵空调亚洲实验中心)
职责:
••     熟悉测试台系统,确保测试台系统的正常运行
••     熟练使用并操作数据采集系统
••     进行产品的安装及测试工作,测试结果数据整理
••     仪器仪表的定期标定检验
要求:
••     制冷暖通,电气或仪表专业毕业
••     良好的英文阅读能力
••     有测试台经验者更佳
••     有电工或焊工操作证优先
9.Laboratory Electrical Facilities Engineer 实验室电器设备工程师
Job Responsibility
••         Plan and direct electrical power infrastructure for new facility build or existing facility rebuild using New Product Introduction (NPI) methods to meet performance and reliability objectives.
••         Provide electrical power system design support for existing Asian development laboratories
••         Work with test engineering to develop and maintain standardized laboratory test methodology in new facility electrical power design or existing facility rebuild.
••         Design electrical power facility modifications and adaptations to meet specific test requirements.
Job Requirement
••         Bachelor’s degree in engineering required. BSEE preferred.
••         English speaking required
••         Engineering experience preferred.
••         Interest or experience in project leadership required.
••         Experience with electrical power system design and local building codes a plus.
••         Fundamental HVAC technical knowledge a plus.
10. Laboratory Mechanical Facilities Engineer 实验室机械设备工程师
Job Responsibility
••         Plan and direct new facility build or existing facility rebuild using New Product Introduction (NPI) methods to meet performance and reliability objectives.
••         Provide design support for existing Asian development laboratories
••         Work with test engineering to develop and maintain standardized laboratory test methodology in new facility design or existing facility rebuild.
••         Design facility modifications and adaptations to meet specific test requirements.
Job Requirement
••         Bachelor’s degree in engineering required. BSME preferred.
••         Experience with heat transfer computations, air handling computations, pressure code compliance, refrigerant properties, and local building codes a plus.
••         Fundamental HVAC technical knowledge required.
Report to American Engineer Team
11. Mechanical Design Engineer
Engineering position that will work with RS product engineering teams to identify, execute, and implement materials productivity projects.  This includes identifying new suppliers for RS components, qualifying new parts using the NCI process and six sigma tools, and working with local suppliers to lead productivity projects.
Major Responsibilities
••         Assist RS Supply Chain and Engineering in identification and qualification of manufacturers for new RS products.
••         Provide support to suppliers during launch phase of new products
••         Assist RS Quality and Supply Chain leaders in supplier and new part qualification through the NCI System
Education, Experience & Skills
••         BS engineering required
••         2-5 years experience in design engineering
••         Related experience with HVAC or refrigeration systems or components preferred
••         Knowledge of sheet metal and basic electrical design methods.
••         Refrigeration and airflow system design, testing, and qualification methods preferred.
••         Familiarity with design tools such as PRO-E.
••         Familiarity with agency and code requirements: ARI and UL
••         Prior work in metallurgy a plus
Key Competencies
••         Self starter
12. Supplier Quality Engineer
Engineering position that will identify new suppliers for RS components and products, work with suppliers to establish process capabilities and improve their manufacturing quality systems, and qualify new parts using the NCI process and six sigma tools.
••         2-5 years experience in manufacturing process design, layout, and quality systems documentation
••         Six Sigma training as a green belt or black belt, certified belt preferred
••         Competence in the use of the latest measurement/metrology techniques is a plus
••         Familiarity with agency and code requirements: UL, CSA
Key Competencies:
••         Self starter
