查看: 8285|回复: 10
求White,F.M.的Viscous Fluid Flow(3rd edition)
发表于 2006-8-28 04:51:06 | 显示全部楼层 |阅读模式
谁能帮我呢,先谢谢啦
发表于 2006-9-6 18:39:53 | 显示全部楼层
如果有其他外文电子书交换,可以考虑
发表于 2006-9-8 09:43:44 | 显示全部楼层
CFDNHT 说说你要什么外文电子书,我这有一些
White的Viscous Fluid Flow我也找了一阵了,还没有找到
发表于 2006-9-8 14:42:31 | 显示全部楼层
你要的书有32M哦
你先把你的外文书书列表发给我看看啊
说不定我都有呢,我有的:
├─(Ebook-Pdf) Physics - Fluid Mechanics - Frank M White Pdf.zip
    ├─(eBook - pdf) - CFD - Fundamentals_of_Computational_Fluid_Dynamics.pdf
    ├─(ebook-pdf) - Mathematics - A Course in Fluid Mechanics with Vector Field Theory.pdf
    ├─-Engineering- theory(ebook - PDF) - Reference - Fluid Mechanics.pdf
    ├─3D-SIMPLE.rar
    ├─Analogy between the Electromagnetic and Hydrodynamic Equations - Application to Turbulence.pdf
    ├─Anderson J.D. Modern compressible flow (2ed., MGH, 1990)(T)(671s).djvu
    ├─Anderson J.D.Jr. Computational fluid dynamics. The basics with applications (MGH, 1995)(T)(563s).djvu
    ├─Arnold V., Khezin B. Topological Methods in Hydrodynamics (Springer, 1998)(T)(392s).djvu
    ├─BLAZEK__J.__2001_._Computational_Fluid_Dynamics_-_Principles_and_Applications.pdf
    ├─Batchelor. Introduction to fluid dynamics (CUP, 2000)(T)(631s).djvu
    ├─Bloomer.-.Practical.Fluid.Mechanics.For.Engineering.Applications.(2000).djvu
    ├─CFD20Program_1125491771.rar
    ├─CFD_Finite_Volume_Method.pdf
    ├─Chorin A., Marsden J. A Mathematical Introduction to Fluid Mechanics (Springer, 1993)(T)(182s).djvu
    ├─Chorin A., Marsden J.E. Mathematical introduction to fluid mechanics (Springer, draft, 2000)(181s).pdf
    ├─Compressible_Fluid_Flow_Oosthuizen.pdf
    ├─Drazin P. Introduction to Hydrodynamic Stability (CUP, 2002)(276s).djvu
    ├─Egbers C., Pfister G. (eds.) Physics of rotating fluids (proc. Bremen 1999, Springer LNP549, 2000)(445s).pdf
    ├─Fluid Mechanics_Frank M.White
    ├─FluidDynamics.Lister.pdf
    ├─FluidDynamics.Lister.ps
    ├─Foundations of fluid mechanics
    ├─Foundations of fluid mechanics - Gallavotti.djvu
    ├─Fundamentals Of Gas Dynamics (2Ed , Wiley, 2002).pdf
    ├─Fundamentals_of_the_Finite_Element_Method_for_Heat_and_Fluid_Flow.pdf
    ├─Intermediate_Fluid Mechanics_Lecture Notes.pdf
    ├─Introduction to Fluid Mechanics Solutions Manual (Fox, 5th ed).pdf
    ├─Lagrangian!uid descriptionwith simple applications in compressible plasma and gas dynamics.pdf
    ├─Lomax-Pulliam-Zingg - Fundamentals of Computational Fluid Dynamics [1999].pdf
    ├─Lumley J.L. (ed.) Fluid mechanics and the environment.. dynamical approaches (LNP566, Springer, 2001)(T)(412s).djvu
    ├─McComb W.D. The physics of fluid turbulence (Oxford, 1991)(T)(595s).djvu
    ├─Milne-Thomson - Theoretical Aerodynamics.pdf
    ├─Modern_compressible_flow.djvu
    ├─Modern_compressible_flow.pdf
    ├─Myshkis A.D., et al. Low-Gravity Fluid Mechanics (Springer, 1987)(601s).djvu
    ├─Pozrikidis C. Fluid dynamics. Theory, computation and numerical simulation (Kluwer, 2001)(T)(557s).djvu
    ├─Springer - Computational Methods for Fluid Dynamics, 3rd Ed [Scan, OCR] - 2002 - (By Laxxuss).pdf
    ├─The finite element method. Fluid dynamics_Zienkiewicz_Taylor(2000)(T).djv
    ├─Thermodynamic_Fluids.pdf
    ├─Viscous_Fluid_Flow
    ├─Wesseling P. Principles of computational fluid dynamics (Springer, 2001)(T)(652s).djvu
    ├─ZUCKER_Fundamentals of Gas Dynamics 2nd.pdf
    ├─Zienkiewicz-Taylor_The finite element method Fluid dynamics vol3.djvu
    ├─ferziger.&.peric.-.computational.methods.for.fluid.dynamics.(3ed,.2001).djvu
    ├─fluids2.ps
    ├─mecanica de fluidos.pdf
    ├─sola—vof.for
发表于 2006-9-8 16:09:33 | 显示全部楼层
发表于 2006-9-8 18:58:49 | 显示全部楼层
这些是我的流体力学类英文书籍的目录,绝大多数都在这里了,刚又下了几本,有关于实验的也有关于飞机的,还有关于航空发动机的,估计你不关心。
看来我们的目录是差不多的,只有个别的不同,不过在网上也不是很难下到。
关于流体实验的书如果你需要的话就不用问我要了,我认为有一些意思的就会传到我的那一版,就是流体实验版。
呵呵,如果我没有交换的资本那就算了,这一阵子也没有时间看那本书,也不是很急,那让我在慢慢淘淘看。。。
你的资料不少,佩服。。。
发表于 2006-9-8 19:04:06 | 显示全部楼层
你这本White的Viscous Fluid Flow应该和我们都有的那本White的Fluid Mechanics一样都是最新的印刷版吧,打印出来就和书一样了,很有收藏价值。
发表于 2006-9-9 09:35:11 | 显示全部楼层
看了你发的图片,你确认你图片中的那本Viscous Fluid Flow 是White的吗?我这也有一本Viscous Fluid Flow ,目录和你图片显示的完全一样,但不是White的,这本书有10章,好像White的书只有7章,White的Viscous Fluid Flow 还是比较经典的,就好像那本Boundary Layer Thoery一样,虽然写的人很多,但是都没有这一本经典。好像White的Viscous Fluid Flow 的中文版都很难找
发表于 2006-9-11 16:40:21 | 显示全部楼层
呼呼,是的,不是White。跟你说的一致
哈哈,搞错了,那就估计网上找不到了。不好意思哦
发表于 2007-3-8 02:59:54 | 显示全部楼层
http://www.bylm.net/forum/read.php?tid=59693
这里有最新版的电子版的,但是下载有些慢的,
但是可以下载的,并且我也是做流体方面的,希望可以交个朋友的!
 楼主| 发表于 2007-8-21 00:41:11 | 显示全部楼层
下面引用由uakron在 2007/03/08 02:59am 发表的内容:
非常感谢啊
