查看: 2256|回复: 3
ansys10安装怎么会出现这样的错误?
发表于 2006-1-22 00:02:05 | 显示全部楼层 |阅读模式
各位大虾,请帮忙看一下,我刚刚安装了ansys9,按照指示去做的,可是不知道为什么会在点击:开始/程序/ansys9.0/ansys时,出现这样的错误。
万分感谢啊
 楼主| 发表于 2006-1-22 00:05:06 | 显示全部楼层
图片如上
 楼主| 发表于 2006-1-22 00:08:08 | 显示全部楼层
我按照Ansys Classic 9.0操作步骤做的,但还是有错
1. Open the crack directory and edit the ansys.dat file. Change host to your computer
   name and 00000000000 to your computer hostid and save the file. Run the keygen.bat
   file which will create a license.dat
   000000000000 1055
2. Run setup and install all options and Install the license server as a single server.
   When prompted for a license file point the browser to the license.dat created in
   step 1.
3. Set the environment:
   ANSYSLMD_LICENSE_FILE = 1055@host  (host being your computer name)
4. Reboot.
发表于 2006-1-22 22:00:16 | 显示全部楼层
应该是licens的问题,你再认真看看吧!看看是不是那个地方搞错了!
