查看: 2182|回复: 0
[求助]急啊,有没有做隧道开挖的高手啊
发表于 2006-10-26 20:13:51 | 显示全部楼层 |阅读模式
我是个菜鸟,仿照参考书做的隧道开挖,怎么不行啊,每次都会出现:
*** ERROR ***                           CP=   1403.766   TIME= 15:18:44
One or more elements have become highly distorted.  Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere.  Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size).  You
may need to improve your mesh to obtain elements with better aspect
ratios.  Also consider the behavior of materials, contact pairs,
and/or constraint equations.  If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
为什么会这样啊,怎么改啊?
