查看: 5928|回复: 5
Future: cloud computing
发表于 2008-2-26 07:24:02 | 显示全部楼层 |阅读模式
Cloud computing is a computing paradigm in which tasks are assigned to a combination of connections, software and services accessed over a network. This network of servers and connections is collectively known as "the cloud." Computing at the scale of the cloud allows users to access supercomputer-level power. Using a thin client or other access point, like an iPhone, BlackBerry or laptop, users can reach into the cloud for resources as they need them. For this reason, cloud computing has also been described as "on-demand computing."
This vast processing power is made possible though distributed, large-scale cluster computing, often in concert with server virtualization software, like Xen, and parallel processing. Cloud computing can be contrasted with the traditional desktop computing model, where the resources of a single desktop computer are used to complete tasks, and an expansion of the client/server model. To paraphrase Sun Microsystems'; famous adage, in cloud computing the network becomes the supercomputer.
Cloud computing is often used to sort through enormous amounts of data. In fact, Google has an initial edge in cloud computing precisely because of its need to produce instant, accurate results for millions of incoming search inquries every day, parsing through the terabytes of Internet data cached on its servers. Google';s approach has been to design and manufacture hundreds of thousands of its own servers from commodity components, connecting relatively inexpensive processors in parallel to create an immensely powerful, scalable system. Google Apps, Maps and Gmail are all based in the cloud. Other companies have already created Web-based operating systems that collect online applications into Flash-based graphic user interfaces (GUIs), often using a look and feel intentionally quite similar to Windows. Hundreds of organizations are already offering free Web services in the cloud.
In many ways, however, cloud computing is simply a buzzword used to repackage grid computing and utility computing, both of which have existed for decades. Like grid computing, cloud computing requires the use of software that can divide and distribute components of a program to thousands of computers. New advances in processors, virtualization technology, disk storage, broadband Internet access and fast, inexpensive servers have all combined to make cloud computing a compelling paradigm. Cloud computing allows users and companies to pay for and use the services and storage that they need, when they need them and, as wireless broadband connection options grow, where they need them. Customers can be billed based upon server utlilization, processing power used or bandwidth consumed. As a result, cloud computing has the potential to upend the software industry entirely, as applications are purchased, licensed and run over the network instead of a user';s desktop. This shift will put data centers and their administrators at the center of the distributed network, as processing power, electricity, bandwidth and storage are all managed remotely.
 楼主| 发表于 2008-2-26 07:28:35 | 显示全部楼层
CFD packages can be applied in this way too. Send your control file over through the network and get the results in short time.
发表于 2008-2-27 18:18:53 | 显示全部楼层
Sounds fantastic, but I think this will depend on two factors: first, there must have a robust computer grid; second, the bandwidth of the network must be wide enough . There is a charllenge to this idea, that is as the CPU became more and more powerful, we can see in the near future, 4-core, 8-core, even 16-core CPU will enter the market soon. So, the charllenge is while people got there own powerful PCs (16-core?), do they still need ';cloud computing';. Maybe, I guess, the cloud computing will only be interested by researchers who need to do the long-term weather forcast. Sorry for this negative comments.
 楼主| 发表于 2008-2-29 07:32:19 | 显示全部楼层
While computers are getting more powerful, people are making their cases larger. People use
1 million elements for one case today and may want to use 10 million elements for the same t
case for tomorrow.
发表于 2008-3-2 18:50:39 | 显示全部楼层
Yes, that will make some sense. We can expect to adopt LES/DNS instead of turbulence modelling with cloud computing. But, the network must be updated, otherwise, the message send/receive may encounter unbearable delay, therefore we can see no goodness from this cloud computing idea. It';s my experience that with 1 Gegabyte memory, we can run a case with approximally 1 million meshes, so if i have 16-core desktop with 16 Gega Memory, i can run a case with more than 10 million meshes, this scale of mesh can be found in aerospace application in present day. so, again, why we need a ';cloud computing'; ?
发表于 2009-3-5 16:35:51 | 显示全部楼层
跟帖是一种友情 是一种欣赏别人的善良!
登录/注册后可看大图
人又不聪明,还学人家秃顶!!
麦考林卓越问道下载当当网dhc
