查看: 3376|回复: 0
简单 快速 精确的系统级热设计软件!
发表于 2005-2-17 17:05:20 | 显示全部楼层 |阅读模式
MACROFLOW
MacroFlow Significantly Improves the Productivity of the Thermal Design Process
Simple, Fast, and Accurate Tool for System-Level Thermal Design
MacroFlowTM Significantly Improves the Productivity of the Thermal Design Process
牋?MacroFlow is a unique software tool for simple, fast, and accurate analysis of the thermal performance of electronics cooling systems based on the technique of Flow Network Modeling (FNM). The conventional approaches of hand calculations/spreadsheets or CFD have significant drawbacks when used for system-level thermal design. Hand calculations are prone to error while spreadsheets are system-specific and inflexible. CFD, on the other hand, is time consuming in terms of model setup, calculations, and examination of results. The FNM technique provides flexibility, accuracy, and speed. In this technique, the cooling system is represented as a network of flow paths and components possessing overall characteristics for quick prediction of the systemwide flow and temperature distributions.
牋?MacroFlow enables thermal engineers to realize the promise of the FNM technique for obtaining significant productivity improvements in the design process. It has the following capabilities:
Intuitive Graphical User Interface (GUI) ?An easy-to-use point-and-click interface and a comprehensive component library allows easy construction of the network models for all practical electronics systems.
Component Library ?The library of components contains standard flow components such as bends, area changes, orifices, and tee-junctions as well as electronics cooling components such as heat sinks, filters, fans, and power supplies. Empirical correlations based on the geometry and flow conditions are already incorporated to determine the flow and heat transfer characteristics of the components. Further, the library can be customized by the user by specifying flow and thermal resistances in various mathematical forms.
Powerful Solution Method ?MacroFlow a direct solution technique for robust and rapid calculation. Results for a typical system are obtained in less than a minute on a PC.
Comprehensive Postprocessing - Systemwide flow and temperature distributions can be examined in the form of bar charts, tables, on-screen display, and animation.
牋牋 MacroFlow is useful for addressing the following system-level thermal design issues:
Examination of different physical layouts
揥hat If?studies such as fan failure, rise in ambient temperature, and filter degradation
Sizing of fans, heat sinks, screens, and filters
Identification of performance-limiting components
Effect of heat sink bypass
Systemwide effects of a design change
牋?Use of MacroFlow enables the thermal engineer to address 80% of the design problems is less than 10% of the time relative to the conventional methods such as spreadsheets or detailed CFD analysis. Its use early in the design cycle allows hundreds of design options to be examined within a day to quickly arrive at a few good designs for detailed analysis and laboratory testing. MacroFlow dramatically improves the productivity of the thermal design process and significantly shortens the design cycle.
牋?MacroFlow is being widely used for the thermal design of air and liquid-cooled systems in computer, telecommunication, peripheral, defense, aerospace, semiconductor, and power electronics industries. Examples of the systems designed using MacroFlow include air-cooled servers, telecom cabinets, projectors, and liquid-cooled test equipment and cold plates. A number of case studies describing such applications are available on our website
http://www.inres.com/Products/MacroFlow_Electronic/Case_Studies/case_studies.html
MACROFLOW
                                                           ---电子冷却系统快速热设计软件
准确定位:快速分析软件
Macroflow软件填补了快速但电子表格处理能力有限的软件和功能详细但特别费时的CFD分析软件之间的空缺。软件应用了流体网络建模技术,对电子系统的温度分配和动态分析相当精确,快速。
软件拥有方便易用的接口,丰富的且用户可自定义的组件库,高效率的算法。Macroflow软件是一种方便,快速,精确的系统级热设计软件。在设计过程中,可以对成百上千个选择进行评估,从而挑选出其中最优的几个方案,缩短设计周期,使产品更快进入市场。
网络建模简单
Macroflow软件的图解式用户界面可以帮助你更快速更容易的对实际电子系统建立网络模型。
       *方便易用的GUI允许你在建模时凭直觉使用组件,对组件进行连接。
       *可以通过对话框对组件进行定义。
       *单位模板,总体编辑,建模迅速使软件效率非常高。
强大的组件库
为分析实际的空气冷却和液体冷却电子系统,Macroflow软件提供了丰富且用户可自定义的组件库。
         *可以表示流体通道几何性质的标准组件,如管道,变径,孔等。
         *电子冷却组件如过滤器,风扇,泵,集成线路板阵列等,使你更精确的表示电子冷却系统的特别之处。
         *用户可以多种功能形式自己定义流体和热传递的特性,并将他们储存在自定义数据库,以便利用。
快速稳健的解决之道
对有关于流体速率,压力,温度的方程,Macroflow软件集成了高效稳健的解法。即使是再复杂的方程,也可以在PC机上几秒钟内计算出结果。
丰富的后处理能力
流体和温度分配的结果可以以下方式进行测试:
          *通过压力图对各种组件的性能进行进一步的测试。
          *计算量的表格式输出。
          *在网络模型上显示结果。
          *动画显示。
应用场合
无论对开环或者闭环,空气冷却或者液体冷却进行分析,Macroflow软件都是非常有用的。他正被广泛的应用于以下方面:
           *PC,服务器,超级计算机
           *室内或者户外通讯设备
           *陆海空国防电子设备
           *半导体测试装置
   气体冷却
    液体冷却
优点与特征
图解式用户界面
强大的计算引擎
结果验证功能
对假设事故进行评估
降低对设计进行更改的风险
