查看: 4522|回复: 6
Chemkin-II的Fortran程序
发表于 2005-5-6 21:14:06 | 显示全部楼层 |阅读模式
      PROGRAM CKINTP
      IMPLICIT DOUBLE PRECISION (A-H,O-Z), INTEGER (I-N)
      PARAMETER (MDIM=10, KDIM=155, MKDIM=MDIM*KDIM, IDIM=1030, LSYM=16,
     1           NPAR=3, NPIDIM=IDIM*NPAR, NPC=5, NPCP2=NPC+2, MAXTP=3,
     2           NTR=MAXTP-1, NKTDIM=NTR*NPCP2*KDIM, MAXSP=6, MAXTB=10,
     3           NLAR=2, NSIDIM=MAXSP*IDIM, NTIDIM=MAXTB*IDIM,
     4           NLIDIM=NLAR*IDIM, NFAR=8, NFIDIM=NFAR*IDIM,
     5           NTDIM=KDIM*MAXTP, NIDIM=11*IDIM, LIN=15, LOUT=16,
     6           LTHRM=17, LINC=25, CKMIN=1.0E-3, MAXORD=KDIM,
     7           NOIDIM=MAXORD*IDIM)
C
      CHARACTER KNAME(KDIM)*(LSYM), ENAME(MDIM)*(LSYM), SUB(80)*80,
     1          KEY(5)*4, LINE*80, IUNITS*80, AUNITS*4, EUNITS*4,
     2          UPCASE*4, VERS*(LSYM), PREC*(LSYM)
C
      DIMENSION AWT(MDIM), KNCF(MDIM,KDIM), WTM(KDIM), KPHSE(KDIM),
     1          KCHRG(KDIM), A(NPCP2,NTR,KDIM), T(MAXTP,KDIM), NT(KDIM),
     2          NSPEC(IDIM), NREAC(IDIM), NU(MAXSP,IDIM),
     3          NUNK(MAXSP,IDIM), PAR(NPAR,IDIM), IDUP(IDIM),IREV(IDIM),
     4          RPAR(NPAR,IDIM), ILAN(IDIM), PLAN(NLAR,IDIM),
     5          IRLT(IDIM), RLAN(NLAR,IDIM), IWL(IDIM),  WL(IDIM),
     6          IFAL(IDIM), IFOP(IDIM), KFAL(IDIM), PFAL(NFAR,IDIM),
     7          ITHB(IDIM),NTBS(IDIM),AIK(MAXTB,IDIM),NKTB(MAXTB,IDIM),
     8          IRNU(IDIM), RNU(MAXSP,IDIM), IORD(IDIM),
     9          KORD(MAXORD,IDIM), RORD(MAXORD,IDIM)
      DIMENSION VALUE(5)
C
      LOGICAL KERR, THERMO, ITHRM(KDIM)
C
      PARAMETER (NJAR=9, NF1R=4, NJIDIM=NJAR*IDIM, NF1IDIM=NF1R*IDIM)
      DIMENSION IEIM(IDIM), ITDEP(IDIM), IJAN(IDIM), PJAN(NJAR,IDIM),
     1          IFT1(IDIM), PFT1(NF1R,IDIM), IEXC(IDIM), PEXC(IDIM)
      DATA NEIM,NJAN,NFT1,NEXC/4*0/, IEIM/IDIM*0/, ITDEP/IDIM*0/,
     1     IJAN/IDIM*0/, IFT1/IDIM*0/, PJAN/NJIDIM*0.0/,
     2     PFT1/NF1IDIM*0.0/, PEXC/IDIM*0.0/
C
C     Initialize variables
C
      DATA KEY/';ELEM';,';SPEC';,';THER';,';REAC';,';END';/, KERR/.FALSE./,
     1     ITASK,NCHRG,MM,KK,II,NLAN,NFAL,NTHB,NREV,NRLT,NWL,
     *     NRNU,NORD/13*0/,
     2     ENAME,AWT/MDIM*'; ';,MDIM*0.0/, THERMO/.TRUE./,
     3     T/NTDIM*-1.0/, KNAME,WTM,NT,KPHSE,KCHRG,ITHRM
     4     /KDIM*'; ';, KDIM*0.0, KDIM*3, KDIM*0, KDIM*0, KDIM*.FALSE./,
     5     WL,IFOP,NTBS,IDUP /IDIM*0.0, IDIM*-1, IDIM*0, IDIM*0/,
     6     NSPEC,NREAC,IREV,ILAN,IRLT,IWL,IFAL,KFAL,ITHB,IRNU,IORD
     7     /NIDIM*0/
C
      DATA NUNK,NU/NSIDIM*0, NSIDIM*0/, NKTB,AIK/NTIDIM*0,NTIDIM*-1.0/
      DATA RNU/NSIDIM*0.0/, KORD/NOIDIM*0/, RORD/NOIDIM*0.0/
      DATA PAR,RPAR/NPIDIM*0.0, NPIDIM*0.0/
      DATA PLAN,RLAN/NLIDIM*0.0, NLIDIM*0.0/
      DATA PFAL/NFIDIM*0.0/, KNCF/MKDIM*0.0/, A/NKTDIM*0.0/
C----------------------------------------------------------------------C
C
      OPEN (LOUT, FORM=';FORMATTED';, STATUS=';UNKNOWN';, FILE=';chem.out';)
C
      VERS = ';3.9';
      WRITE  (LOUT, 15) VERS(:4)
   15 FORMAT (/
     1'; CHEMKIN INTERPRETER OUTPUT: CHEMKIN-II Version ';,A,'; Aug. 1994';
C*****precision > double
     2/';                              DOUBLE PRECISION';/)
      PREC = ';DOUBLE';
      OPEN (LIN, FORM=';FORMATTED';, STATUS=';OLD';, FILE=';chem.inp';,
     1      ERR=11111)
      READ (LIN,';(A)';,END=11111)
      REWIND (LIN)
  100 CONTINUE
      LINE = '; ';
      READ (LIN,';(A)';,END=5000) LINE
  105 CONTINUE
      ILEN = IPPLEN(LINE)
      IF (ILEN .EQ. 0) GO TO 100
C
      CALL CKISUB (LINE(:ILEN), SUB, NSUB)
C
C        IS THERE A KEYWORD?
C
      CALL CKCOMP ( UPCASE(SUB(1), 4) , KEY, 5, NKEY)
      IF (NKEY .GT. 0) ITASK = 0
C
      IF (NKEY.EQ.1 .OR. NKEY.EQ.2) THEN
C
C        ELEMENT OR SPECIES DATA
C
         ITASK = NKEY
         IF (NSUB .EQ. 1) GO TO 100
C
         DO 25 N = 2, NSUB
            SUB(N-1) = '; ';
            SUB(N-1) = SUB(N)
   25    CONTINUE
         NSUB = NSUB-1
C
      ELSEIF (NKEY .EQ. 3) THEN
C
C        THERMODYNAMIC DATA
C
         IF (NSUB .GT. 1) THEN
            IF ( UPCASE(SUB(2), 3) .EQ. ';ALL';) THEN
               THERMO = .FALSE.
               READ (LIN,';(A)';) LINE
               CALL IPPARR (LINE, -1, 3, VALUE, NVAL, IER, LOUT)
               IF (NVAL .NE. 3 .OR. IER.NE.0) THEN
                  KERR = .TRUE.
                  WRITE (LOUT, 333)
               ELSE
                  TLO = VALUE(1)
                  TMID = VALUE(2)
                  THI = VALUE(3)
               ENDIF
            ENDIF
         ELSE
C
C           USE THERMODYNAMIC DATABASE FOR DEFAULT TLO,TMID,THI
            OPEN (LTHRM, FORM=';FORMATTED';, STATUS=';OLD';,
     1                   FILE=';therm.dat';, ERR=22222)
C
  311       CONTINUE
            READ (LTHRM,';(A)';,END=22222) LINE
            IF (IPPLEN(LINE).LE.0 .OR. INDEX(LINE,';THERMO';).GT.0
     1          .OR. INDEX(LINE,';thermo';).GT.0) GO TO 311
C
               KERR = .TRUE.
               WRITE (LOUT, 333)
            ELSE
               TLO = VALUE(1)
               TMID = VALUE(2)
               THI = VALUE(3)
            ENDIF
            CLOSE (LTHRM)
         ENDIF
C
         CALL CKTHRM (LIN, MDIM, ENAME, MM, AWT, KNAME, KK, KNCF,
     1                KPHSE, KCHRG, WTM, MAXTP, NT, NTR, TLO, TMID,
     2                THI, T, NPCP2, A, ITHRM, KERR, LOUT, LINE)
C
         IF (.NOT. THERMO)
     1      CALL CKPRNT (MDIM, MAXTP, MM, ENAME, KK, KNAME, WTM, KPHSE,
     2                   KCHRG, NT, T, TLO, TMID, THI, KNCF, ITHRM,
     3                   LOUT, KERR)
         I1 = IFIRCH(LINE)
         IF (UPCASE(LINE(I1, 4) .EQ. ';REAC';) GO TO 105
C
      ELSEIF (NKEY .EQ. 4) THEN
C
         ITASK = 4
C        START OF REACTIONS; ARE UNITS SPECIFIED?
         CALL CKUNIT (LINE(:ILEN), AUNITS, EUNITS, IUNITS)
C
         IF (THERMO) THEN
C
  312       CONTINUE
            IF (IPPLEN(LINE).LE.0 .OR. INDEX(LINE,';THERM';).GT.0
     1          .OR. INDEX(LINE,';therm';).GT.0) GO TO 312
C
               KERR = .TRUE.
               WRITE (LOUT, 333)
            ELSE
               TLO = VALUE(1)
               TMID = VALUE(2)
               THI = VALUE(3)
            ENDIF
            CALL CKTHRM (LTHRM, MDIM, ENAME, MM, AWT, KNAME, KK, KNCF,
     1                   KCHRG, NT, T, TLO, TMID, THI, KNCF, ITHRM,
     2                   LOUT, KERR)
            THERMO = .FALSE.
            CLOSE (LTHRM)
         ENDIF
C
         WRITE (LOUT, 1800)
         GO TO 100
      ENDIF
C
      IF (ITASK .EQ. 1) THEN
C
C        ELEMENT DATA
C
         IF (MM .EQ. 0) THEN
            WRITE (LOUT, 200)
            WRITE (LOUT, 300)
            WRITE (LOUT, 200)
         ENDIF
C
         IF (NSUB .GT. 0) THEN
            M1 = MM +1
            CALL CKCHAR (SUB, NSUB, MDIM, ENAME, AWT, MM, KERR, LOUT)
            DO 110 M = M1, MM
               IF (AWT(M) .LE. 0) CALL CKAWTM (ENAME(M), AWT(M))
               WRITE (LOUT, 400) M,ENAME(M)(:4),AWT(M)
               IF (AWT(M) .LE. 0) THEN
                  KERR = .TRUE.
                  WRITE (LOUT, 1000) ENAME(M)
               ENDIF
  110       CONTINUE
         ENDIF
C
      ELSEIF (ITASK .EQ. 2) THEN
C
C        PROCESS SPECIES DATA
C
         IF (KK .EQ. 0) WRITE (LOUT, 200)
         IF (NSUB .GT. 0)
     1   CALL CKCHAR (SUB, NSUB, KDIM, KNAME, WTM, KK, KERR, LOUT)
C
      ELSEIF (ITASK .EQ. 4) THEN
C
C        PROCESS REACTION DATA
C
         IND = 0
         DO 120 N = 1, NSUB
            IND = MAX(IND, INDEX(SUB(N),';/';))
            IF (UPCASE(SUB(N), 3) .EQ. ';DUP';) IND = MAX(IND,1)
  120    CONTINUE
         IF (IND .GT. 0) THEN
C
C           AUXILIARY REACTION DATA
C
            CALL CKAUXL (SUB, NSUB, II, KK, KNAME, LOUT, MAXSP, NPAR,
     1                   NSPEC, NTHB, ITHB, NTBS, MAXTB, NKTB, AIK,
     2                   NFAL, IFAL, IDUP, NFAR, PFAL, IFOP, NLAN,
     3                   ILAN, NLAR, PLAN, NREV, IREV, RPAR, NRLT, IRLT,
     4                   RLAN, NWL, IWL, WL, KERR, NORD, IORD, MAXORD,
     5                   KORD, RORD, NUNK, NU, NRNU, IRNU, RNU,
     6                   NEIM, IEIM, ITDEP, NJAN, IJAN, NJAR, PJAN,
     7                   NFT1, IFT1, NF1R, PFT1, NEXC, IEXC, PEXC)
C
         ELSE
C
C           THIS IS A REACTION STRING
C
            IF (II .LT. IDIM) THEN
C
               IF (II .GT. 0)
C
C              CHECK PREVIOUS REACTION FOR COMPLETENESS
C
     1         CALL CPREAC (II, MAXSP, NSPEC, NPAR, PAR, RPAR,
     2                      AUNITS, EUNITS, NREAC, NUNK, NU, KCHRG,
     3                      MDIM, MM, KNCF, IDUP, NFAL, IFAL, KFAL,
     4                      NFAR, PFAL, IFOP, NREV, IREV, NTHB, ITHB,
     5                      NLAN, ILAN, NRLT, IRLT, KERR, LOUT, NRNU,
     6                      IRNU, RNU, CKMIN)
C
C              NEW REACTION
C
               II = II+1
               CALL CKREAC (LINE(:ILEN), II, KK, KNAME, LOUT, MAXSP,
     1                      NSPEC, NREAC, NUNK, NU, NPAR, PAR,
     2                      NTHB, ITHB, NFAL, IFAL, KFAL, NWL,
     3                      IWL, WL, NRNU, IRNU, RNU, KERR)
C
            ELSE
               WRITE (LOUT, 1070)
               KERR = .TRUE.
            ENDIF
C
         ENDIF
      ENDIF
      GO TO 100
C
5000 CONTINUE
      IF (II .GT. 0) THEN
          CALL CPREAC (II, MAXSP, NSPEC, NPAR, PAR, RPAR, AUNITS,
     1                 EUNITS, NREAC, NUNK, NU, KCHRG, MDIM, MM,
     2                 KNCF, IDUP, NFAL, IFAL, KFAL, NFAR, PFAL, IFOP,
     3                 NREV, IREV, NTHB, ITHB, NLAN, ILAN, NRLT,
     4                 IRLT, KERR, LOUT, NRNU, IRNU, RNU, CKMIN)
         DO 500 I = 1, II
            IF (IDUP(I) .LT. 0) THEN
               KERR = .TRUE.
               WRITE (LOUT, 1095) I
            ENDIF
  500    CONTINUE
C
         WRITE (LOUT, ';(/1X,A)';) '; NOTE: ';//IUNITS(:ILASCH(IUNITS))
C
      ELSEIF (THERMO) THEN
C
  313    CONTINUE
     1       .OR. INDEX(LINE,';therm';).GT.0) GO TO 313
C
            KERR = .TRUE.
            WRITE (LOUT, 333)
         ELSE
            TLO = VALUE(1)
            TMID = VALUE(2)
            THI = VALUE(3)
         ENDIF
     2                LOUT, KERR)
         CLOSE  (LTHRM)
      ENDIF
C
      CLOSE (LIN)
      OPEN (LINC, FORM=';UNFORMATTED';, STATUS=';UNKNOWN';,
     1            FILE=';chem.bin';)
      WRITE (LINC) VERS, PREC, KERR
C
      IF (KERR) THEN
         WRITE (LOUT, ';(//A)';)
     1   '; WARNING...THERE IS AN ERROR IN THE LINKING FILE';
         CLOSE (LINC)
         CLOSE (LOUT)
         STOP
      ENDIF
C
      DO 1150 K = 1, KK
         IF (KCHRG(K) .NE. 0) NCHRG = NCHRG+1
1150 CONTINUE
C
      LENICK = 1 + (3 + MM)*KK + (2 + 2*MAXSP)*II + NLAN + NRLT
     1           + 3*NFAL + (2 + MAXTB)*NTHB + NREV + NWL + NRNU
     2           + NORD*(1 + MAXORD) + 2*NEIM + NJAN + NFT1
     3           + NEXC
C
      LENCCK = MM + KK
C
      LENRCK = 3 + MM + KK*(5 + MAXTP + NTR*NPCP2) + II*7 + NREV
     1           + NPAR*(II + NREV) + NLAR*(NLAN + NRLT)
     2           + NFAR*NFAL + MAXTB*NTHB + NWL + NRNU*MAXSP
     3           + NORD*MAXORD + NJAR*NJAN + NF1R*NFT1 + NEXC
C
      WRITE (LINC) LENICK, LENRCK, LENCCK, MM, KK, II, MAXSP,
     1             MAXTB, MAXTP, NPC, NPAR, NLAR, NFAR, NREV, NFAL,
     2             NTHB, NLAN, NRLT, NWL, NCHRG, NEIM, NJAR, NJAN,
     3             NF1R, NFT1, NEXC, NRNU, NORD, MAXORD, CKMIN
      WRITE (LINC) (ENAME(M), AWT(M), M = 1, MM)
      WRITE (LINC) (KNAME(K), (KNCF(M,K),M=1,MM), KPHSE(K),
     1              KCHRG(K), WTM(K), NT(K), (T(L,K),L=1,MAXTP),
     2              ((A(M,L,K), M=1,NPCP2), L=1,NTR), K = 1, KK)
C
      IF (II .GT. 0) THEN
C
         WRITE (LINC) (NSPEC(I), NREAC(I), (PAR(N,I), N = 1, NPAR),
     1         (NU(M,I), NUNK(M,I), M = 1, MAXSP), I = 1, II)
C
         IF (NREV .GT. 0) WRITE (LINC)
     1      (IREV(N),(RPAR(L,N),L=1,NPAR),N=1,NREV)
C
         IF (NFAL .GT. 0) WRITE (LINC)
     1      (IFAL(N),IFOP(N),KFAL(N),(PFAL(L,N),L=1,NFAR), N = 1, NFAL)
C
         IF (NTHB .GT. 0) WRITE (LINC)
     1      (ITHB(N),NTBS(N),(NKTB(M,N),AIK(M,N),M=1,MAXTB),N=1,NTHB)
C
         IF (NLAN .GT. 0) WRITE (LINC)
     1      (ILAN(N), (PLAN(L,N), L = 1, NLAR), N = 1, NLAN)
C
         IF (NRLT .GT. 0) WRITE (LINC)
     1      (IRLT(N), (RLAN(L,N), L = 1, NLAR), N=1,NRLT)
C
         IF (NWL .GT. 0) WRITE (LINC) (IWL(N), WL(N), N = 1, NWL)
C
         IF (NEIM .GT. 0) WRITE (LINC) (IEIM(N),ITDEP(N),N=1,NEIM)
C
         IF (NJAN .GT. 0) WRITE (LINC)
     1      (IJAN(N), (PJAN(L,N), L = 1, NJAR), N = 1, NJAN)
C
         IF (NFT1 .GT. 0) WRITE (LINC)
     1      (IFT1(N), (PFT1(L,N), L = 1, NF1R), N = 1, NFT1)
C
         IF (NEXC .GT. 0) WRITE (LINC)
     1      (IEXC(N), PEXC(N), N=1, NEXC)
         IF (NRNU .GT. 0) WRITE (LINC)
     1      (IRNU(N), (RNU(M,N), M = 1, MAXSP), N = 1, NRNU)
         IF (NORD .GT. 0) WRITE (LINC)
     1      (IORD(N), (KORD(L,N), RORD(L,N), L=1, MAXORD), N=1,NORD)
      ELSE
         WRITE (LOUT, ';(/A)';)
     1      '; WARNING...NO REACTION INPUT FOUND; ';,
     2      '; LINKING FILE HAS NO REACTION INFORMATION ON IT.';
      ENDIF
C
      WRITE (LOUT, ';(///A)';)
     1   '; NO ERRORS FOUND ON INPUT...CHEMKIN LINKING FILE WRITTEN.';
C
      WRITE (LOUT, ';(/A,3(/A,I6))';)
     1      '; WORKING SPACE REQUIREMENTS ARE';,
     2      ';    INTEGER:   ';,LENICK,
     3      ';    REAL:      ';,LENRCK,
     4      ';    CHARACTER: ';,LENCCK
      CLOSE (LINC)
      CLOSE (LOUT)
      STOP
11111 CONTINUE
      WRITE (LOUT,*) '; Error...cannot read chem.inp...';
      CLOSE (LIN)
      STOP 2
22222 CONTINUE
      WRITE (LOUT,*) '; Error...cannot read therm.dat...';
      CLOSE (LTHRM)
      STOP 2
      END
      SUBROUTINE CKCHAR (SUB, NSUB, NDIM, STRAY, RAY, NN, KERR, LOUT)
      DIMENSION RAY(*), PAR(1)
      CHARACTER*(*) SUB(*), STRAY(*)
      CHARACTER ISTR*80, UPCASE*4
      LOGICAL KERR
C
      ILEN = LEN(STRAY(1))
C
      DO 200 N = 1, NSUB
         IF ( UPCASE(SUB(N), 3) .EQ. ';END';) RETURN
         ISTR = '; ';
         I1 = INDEX(SUB(N),';/';)
         IF (I1 .EQ .1) THEN
            KERR = .TRUE.
            WRITE (LOUT, 130) SUB(N)(:ILASCH(SUB(N)))
         ELSE
            IF (I1 .LE. 0) THEN
               ISTR = SUB(N)
            ELSE
               ISTR = SUB(N)(:I1-1)
            ENDIF
            CALL CKCOMP (ISTR, STRAY, NN, INUM)
C
            IF (INUM .GT. 0) THEN
               WRITE (LOUT, 100) SUB(N)(:ILASCH(SUB(N)))
            ELSE
               IF (NN .LT. NDIM) THEN
                  IF (ISTR(ILEN+1 .NE. '; ';) THEN
                     WRITE (LOUT, 120) SUB(N)(:ILASCH(SUB(N)))
                     KERR = .TRUE.
                  ELSE
                     NN = NN + 1
                     STRAY(NN) = '; ';
                     STRAY(NN) = ISTR(:ILEN)
                     IF (I1 .GT. 0) THEN
                        I2 = I1 + INDEX(SUB(N)(I1+1,';/';)
                        ISTR = '; ';
                        ISTR = SUB(N)(I1+1:I2-1)
                        CALL IPPARR (ISTR, 1, 1, PAR, NVAL, IER, LOUT)
                        KERR = KERR .OR. (IER.NE.0)
                        RAY(NN) = PAR(1)
                     ENDIF
                  ENDIF
               ELSE
                  WRITE (LOUT, 110) SUB(N)(:ILASCH(SUB(N)))
                  KERR = .TRUE.
               ENDIF
            ENDIF
         ENDIF
  200 CONTINUE
      END
      SUBROUTINE CKAWTM (ENAME, AWT)
      PARAMETER (NATOM = 102)
      DIMENSION ATOM(NATOM)
      CHARACTER*(*) ENAME
      CHARACTER*2 IATOM(NATOM), UPCASE
C
      DATA (IATOM(I),ATOM(I),I=1,40) /
     *';H ';,  1.00797, ';HE';,  4.00260, ';LI';,  6.93900, ';BE';,  9.01220,
     *';B ';, 10.81100, ';C ';, 12.01115, ';N ';, 14.00670, ';O ';, 15.99940,
     *';F ';, 18.99840, ';NE';, 20.18300, ';NA';, 22.98980, ';MG';, 24.31200,
     *';AL';, 26.98150, ';SI';, 28.08600, ' ';, 30.97380, ';S ';, 32.06400,
     *';CL';, 35.45300, ';AR';, 39.94800, ';K ';, 39.10200, ';CA';, 40.08000,
     *';SC';, 44.95600, ';TI';, 47.90000, ';V ';, 50.94200, ';CR';, 51.99600,
     *';MN';, 54.93800, ';FE';, 55.84700, ';CO';, 58.93320, ';NI';, 58.71000,
     *';CU';, 63.54000, ';ZN';, 65.37000, ';GA';, 69.72000, ';GE';, 72.59000,
     *';AS';, 74.92160, ';SE';, 78.96000, ';BR';, 79.90090, ';KR';, 83.80000,
     *';RB';, 85.47000, ';SR';, 87.62000, ';Y ';, 88.90500, ';ZR';, 91.22000/
C
      DATA (IATOM(I),ATOM(I),I=41,80) /
     *';NB';, 92.90600, ';MO';, 95.94000, ';TC';, 99.00000, ';RU';,101.07000,
     *';RH';,102.90500, 'D';,106.40000, ';AG';,107.87000, ';CD';,112.40000,
     *';IN';,114.82000, ';SN';,118.69000, ';SB';,121.75000, ';TE';,127.60000,
     *';I ';,126.90440, ';XE';,131.30000, ';CS';,132.90500, ';BA';,137.34000,
     *';LA';,138.91000, ';CE';,140.12000, 'R';,140.90700, ';ND';,144.24000,
     *';PM';,145.00000, ';SM';,150.35000, ';EU';,151.96000, ';GD';,157.25000,
     *';TB';,158.92400, ';DY';,162.50000, ';HO';,164.93000, ';ER';,167.26000,
     *';TM';,168.93400, ';YB';,173.04000, ';LU';,174.99700, ';HF';,178.49000,
     *';TA';,180.94800, ';W ';,183.85000, ';RE';,186.20000, ';OS';,190.20000,
     *';IR';,192.20000, ';PT';,195.09000, ';AU';,196.96700, ';HG';,200.59000/
C
      DATA (IATOM(I),ATOM(I),I=81,NATOM) /
     *';TL';,204.37000, ';PB';,207.19000, ';BI';,208.98000, ';PO';,210.00000,
     *';AT';,210.00000, ';RN';,222.00000, ';FR';,223.00000, ';RA';,226.00000,
     *';AC';,227.00000, ';TH';,232.03800, ';PA';,231.00000, ';U ';,238.03000,
     *';NP';,237.00000, ';PU';,242.00000, ';AM';,243.00000, ';CM';,247.00000,
     *';BK';,249.00000, ';CF';,251.00000, ';ES';,254.00000, ';FM';,253.00000,
     *';D ';,002.01410, ';E';,5.45E-4/
C
      CALL CKCOMP ( UPCASE(ENAME, 2), IATOM, NATOM, L)
      IF (L .GT. 0) AWT = ATOM(L)
      RETURN
      END
      SUBROUTINE CKTHRM (LUNIT, MDIM, ENAME, MM, AWT, KNAME, KK, KNCF,
     2                   THI, T, NPCP2, A, ITHRM, KERR, LOUT, ISTR)
      DIMENSION WTM(*), NT(*), T(MAXTP,*), KPHSE(*), KNCF(MDIM,*),
     1          KCHRG(*), A(NPCP2,NTR,*), AWT(*), VALUE(5)
      CHARACTER*(*) ENAME(*), KNAME(*)
      CHARACTER*80 ISTR, SUB(80), LINE(4)
      CHARACTER ELEM*16, UPCASE*4
      LOGICAL KERR, ITHRM(*)
C
      IF (MM.LE.0 .OR. KK.LE.0) WRITE (LOUT, 80)
C
      GO TO 20
   10 CONTINUE
      ISTR = '; ';
      READ (LUNIT,';(A)';,END=40) ISTR
   20 CONTINUE
      ILEN = IPPLEN(ISTR)
      IF (ILEN .LE. 0) GO TO 10
C
      CALL CKISUB (ISTR(:ILEN), SUB, NSUB)
      IF (UPCASE(SUB(1), 3) .EQ. ';END'; .OR.
     1    UPCASE(SUB(1), 4) .EQ. ';REAC';) RETURN
C
      IF (ILEN.LT.80 .OR. ISTR(80:80).NE.';1';) GO TO 10
      CALL CKCOMP (SUB(1), KNAME, KK, K)
C
      IF (K.LE.0 .OR. ITHRM(K)) GO TO 10
      ITHRM(K) = .TRUE.
      LINE(1) = '; ';
      LINE(1) = ISTR
      L = 2
  111 CONTINUE
      READ (LUNIT,';(A)';,END=40) LINE(L)
      IF (IPPLEN(LINE(L)) .GE. 80) THEN
         IF (LINE(L)(80:80) .EQ. ';4';) THEN
            GO TO 25
         ELSEIF (LINE(L)(80:80).EQ.';2'; .OR.
     1           LINE(L)(80:80).EQ.';3';) THEN
            L = L + 1
         ENDIF
      ENDIF
      GO TO 111
C
   25 CONTINUE
C
      ICOL = 20
      DO 60 I = 1, 5
         ICOL = ICOL + 5
         IF (I .EQ. 5) ICOL = 74
         ELEM  = LINE(1)(ICOL:ICOL+1)
         IELEM = 0
C
         IF (LINE(1)(ICOL+2:ICOL+4) .NE. '; ';) THEN
            CALL IPPARR
     1      (LINE(1)(ICOL+2:ICOL+4), 0, 1, VALUE, NVAL, IER, LOUT)
            IELEM = VALUE(1)
         ENDIF
C
         IF (ELEM.NE.'; '; .AND. IELEM.NE.0) THEN
            IF (UPCASE(ELEM, 1) .EQ. ';E';)
     1             KCHRG(K)=KCHRG(K)+IELEM*(-1)
            CALL CKCOMP (ELEM, ENAME, MM, M)
            IF (M .GT. 0) THEN
               KNCF(M,K) = IELEM
               WTM(K) = WTM(K) + AWT(M)*FLOAT(IELEM)
            ELSE
               WRITE (LOUT, 100) ELEM,KNAME(K)(:10)
               KERR = .TRUE.
            ENDIF
         ENDIF
   60 CONTINUE
C
      IF (UPCASE(LINE(1)(45:),1) .EQ. ';L';) KPHSE(K)=1
      IF (UPCASE(LINE(1)(45:),1) .EQ. ';S';) KPHSE(K)=-1
      T(1,K) = TLO
      IF (LINE(1)(46:55) .NE. '; ';) CALL IPPARR
     1   (LINE(1)(46:55), 0, 1, T(1,K), NVAL, IER, LOUT)
C
      T(2,K) = TMID
      IF (LINE(1)(66:73) .NE. '; ';) CALL IPPARR
     1   (LINE(1)(66:73), 0, 1, T(2,K), NVAL, IER, LOUT)
C
      T(NT(K),K) = THI
      IF (LINE(1)(56:65) .NE. '; ';) CALL IPPARR
     1   (LINE(1)(56:65), 0, 1, T(NT(K),K), NVAL, IER, LOUT)
C
      READ (LINE(2)(:75),';(5E15.8)';) (A(I,NTR,K),I=1,5)
      READ (LINE(3)(:75),';(5E15.8)';)
     1            (A(I,NTR,K),I=6,7),(A(I,1,K),I=1,3)
      READ (LINE(4)(:60),';(4E15.8)';) (A(I,1,K),I=4,7)
      GO TO 10
C
   40 RETURN
      END
      SUBROUTINE CKREAC (LINE, II, KK, KNAME, LOUT, MAXSP, NSPEC, NREAC,
     1                   NUNK, NU, NPAR, PAR, NTHB, ITHB,
     2                   NFAL, IFAL, KFAL, NWL, IWL, WL,
     3                   NRNU, IRNU, RNU, KERR)
      DIMENSION NSPEC(*), NREAC(*), NUNK(MAXSP,*), NU(MAXSP,*),
     1          PAR(NPAR,*), IFAL(*), KFAL(*), ITHB(*), IWL(*), WL(*),
     2          IRNU(*), RNU(MAXSP,*), IPLUS(20)
      CHARACTER*(*) KNAME(*), LINE
      CHARACTER CNUM(11)*1, UPCASE*4
      CHARACTER*80 ISTR, IREAC, IPROD, ISPEC, INAME, ITEMP
      LOGICAL KERR, LTHB, LWL, LRSTO
      DATA CNUM/';.';,';0';,';1';,';2';,';3';,';4';,';5';,';6';,';7';,';8';,';9';/
C
      LTHB = .FALSE.
      LWL = .FALSE.
      NSPEC(II) = 0
      NREAC(II) = 0
      CALL IPNPAR (LINE, NPAR, ISTR, ISTART)
      CALL IPPARR (ISTR, 1, NPAR, PAR(1,II), NVAL, IER, LOUT)
      INAME = '; ';
      ILEN = 0
      DO 10 I = 1, ISTART-1
         IF (LINE(I:I) .NE. '; ';) THEN
            ILEN = ILEN+1
            INAME(ILEN:ILEN) = LINE(I:I)
         ENDIF
   10 CONTINUE
      I1 = 0
      I2 = 0
      DO 25 I = 1, ILEN
         IF (I1 .LE. 0) THEN
            IF (INAME(I:I+2) .EQ. ';<=>';) THEN
               I1 = I
               I2 = I+2
               IR = 1
            ELSEIF (INAME(I:I+1) .EQ. ';=>';) THEN
               I1 = I
               I2 = I+1
               IR = -1
            ELSEIF (I.GT.1 .AND. INAME(I:I).EQ.';=';
     1                  .AND. INAME(I-1:I-1).NE.';=';) THEN
               I1 = I
               I2 = I
               IR = 1
            ENDIF
         ENDIF
   25 CONTINUE
C
      IF (ILASCH(INAME).GE.45 .AND. I1.GT.0) THEN
         WRITE (LOUT, 1900) II,INAME(:I1-1),(PAR(N,II),N=1,NPAR)
         WRITE (LOUT, 1920) INAME(I1:)
      ELSE
          WRITE (LOUT, 1900) II,INAME(:45),(PAR(N,II),N=1,NPAR)
      ENDIF
C
      IREAC = '; ';
      IPROD = '; ';
      IF (I1 .GT. 0) THEN
         IREAC = INAME(:I1-1)
         IPROD = INAME(I2+1:)
      ELSE
         WRITE (LOUT, 660)
         KERR = .TRUE.
         RETURN
      ENDIF
C
      LRSTO = ((INDEX(IREAC,';.';).GT.0) .OR. (INDEX(IPROD,';.';).GT.0))
      IF (LRSTO) THEN
         NRNU = NRNU + 1
         IRNU(NRNU) = II
      ENDIF
C
      IF (INDEX(IREAC,';=>';).GT.0 .OR. INDEX(IPROD,';=>';).GT.0) THEN
         WRITE (LOUT, 800)
         KERR = .TRUE.
         RETURN
      ENDIF
      IF (INDEX(IREAC,';(+';).GT.0 .OR. INDEX(IPROD,';(+';).GT.0) THEN
         KRTB = 0
         KPTB = 0
         DO 300 J = 1, 2
            ISTR = '; ';
            KTB  = 0
            IF (J .EQ. 1) THEN
               ISTR = IREAC
            ELSE
               ISTR = IPROD
            ENDIF
C
            DO 35 N = 1, ILASCH(ISTR)-1
               IF (ISTR(N:N+1) .EQ. ';(+';) THEN
                  I1 = N+2
                  I2 = I1 + INDEX(ISTR(I1:),';)';)-1
                  IF (I2 .GT. I1) THEN
                     IF (ISTR(I1:I2-1).EQ.';M'; .OR.
     1                   ISTR(I1:I2-1).EQ.';m';) THEN
                         IF (KTB .NE. 0) THEN
                            WRITE (LOUT, 630)
                            KERR = .TRUE.
                            RETURN
                         ELSE
                            KTB = -1
                         ENDIF
                     ELSE
                        CALL CKCOMP (ISTR(I1:I2-1), KNAME, KK, KNUM)
                        IF (KNUM .GT. 0) THEN
                              WRITE (LOUT, 630)
                              KERR = .TRUE.
                              RETURN
                           ELSE
                              KTB = KNUM
                           ENDIF
                        ENDIF
                     ENDIF
                        ITEMP = '; ';
                        IF (I1 .EQ. 1) THEN
                           ITEMP = ISTR(I2+1:)
                        ELSE
                           ITEMP = ISTR(:I1-3)//ISTR(I2+1:)
                        ENDIF
                        IF (J .EQ. 1) THEN
                           IREAC = '; ';
                           IREAC = ITEMP
                           KRTB = KTB
                        ELSE
                           IPROD = '; ';
                           IPROD = ITEMP
                           KPTB = KTB
                        ENDIF
                     ENDIF
                  ENDIF
               ENDIF
   35       CONTINUE
  300    CONTINUE
C
         IF (KRTB.NE.0 .OR. KPTB.NE.0) THEN
            IF (KRTB.LE.0 .AND. KPTB.LE.0) THEN
C
               NFAL = NFAL + 1
               IFAL(NFAL) = II
               KFAL(NFAL) = 0
C
               LTHB = .TRUE.
               NTHB = NTHB + 1
               ITHB(NTHB) = II
C
            ELSEIF (KRTB .EQ. KPTB) THEN
               NFAL = NFAL + 1
               IFAL(NFAL) = II
               KFAL(NFAL) = KRTB
C
            ELSE
C
               WRITE (LOUT, 640)
               KERR = .TRUE.
               RETURN
            ENDIF
         ENDIF
      ENDIF
      DO 600 J = 1, 2
         ISTR = '; ';
         LTHB = .FALSE.
         IF (J .EQ. 1) THEN
            ISTR = IREAC
            NS = 0
         ELSE
            ISTR = IPROD
            NS = 3
         ENDIF
         NPLUS = 1
         IPLUS(NPLUS) = 0
         DO 500 L = 2, ILASCH(ISTR)-1
            IF (ISTR(L).EQ.';+';) THEN
               NPLUS = NPLUS + 1
               IPLUS(NPLUS) = L
            ENDIF
  500    CONTINUE
         NPLUS = NPLUS + 1
         IPLUS(NPLUS) = ILASCH(ISTR)+1
C
         NSTART = 1
  505    CONTINUE
         N1 = NSTART
         DO 510 N = NPLUS, N1, -1
            ISPEC = '; ';
            ISPEC = ISTR(IPLUS(N1)+1 : IPLUS(N)-1)
C
            IF (UPCASE(ISPEC, 1).EQ.';M'; .AND.
     1               (ISPEC(2:2).EQ.'; '; .OR. ISPEC(2:2).EQ.';+';)) THEN
               IF (LTHB) THEN
                  WRITE (LOUT, 900)
                  KERR = .TRUE.
                  RETURN
               ELSEIF (NFAL.GT.0 .AND. IFAL(NFAL).EQ.II) THEN
                  WRITE (LOUT, 640)
                  KERR = .TRUE.
                  RETURN
               ELSE
                  LTHB = .TRUE.
                  IF (NTHB.EQ.0 .OR.
     1               (NTHB.GT.0.AND.ITHB(NTHB).NE.II)) THEN
                      NTHB = NTHB + 1
                      ITHB(NTHB) = II
                  ENDIF
                  IF (N .EQ. NPLUS) GO TO 600
                  NSTART = N
                  GO TO 505
               ENDIF
C
            ELSEIF (UPCASE(ISPEC, 2) .EQ. ';HV';) THEN
               IF (LWL) THEN
                  WRITE (LOUT, 670)
                  KERR = .TRUE.
                  RETURN
               ELSE
                  LWL = .TRUE.
                  NWL = NWL + 1
                  IWL(NWL) = II
                  WL(NWL) = 1.0
                  IF (J .EQ. 1) WL(NWL) = -1.0
                  NSTART = N
                  GO TO 505
               ENDIF
            ENDIF
            IND = 0
            DO 334 L = 1, LEN(ISPEC)
               NTEST = 0
               DO 333 M = 1, 11
                  IF (ISPEC(L) .EQ. CNUM(M)) THEN
                     NTEST=M
                     IND = L
                  ENDIF
  333          CONTINUE
               IF (NTEST .EQ. 0) GO TO 335
  334       CONTINUE
  335       CONTINUE
C
            RVAL = 1.0
            IVAL = 1
               IF (LRSTO) THEN
                  CALL IPPARR (ISPEC(:IND), 1, 1, RVAL, NVAL,
     1                         IER, LOUT)
               ELSE
                  CALL IPPARI (ISPEC(:IND), 1, 1, IVAL, NVAL,
     1                        IER, LOUT)
               ENDIF
               IF (IER .EQ. 0) THEN
                  ITEMP = '; ';
                  ITEMP = ISPEC(IND+1:)
                  ISPEC = '; ';
                  ISPEC = ITEMP
               ELSE
                  KERR = .TRUE.
                  RETURN
               ENDIF
            ENDIF
C
            CALL CKCOMP (ISPEC, KNAME, KK, KNUM)
            IF (KNUM .EQ. 0) THEN
               IF ((N-N1) .GT. 1) GO TO 510
               WRITE (LOUT, 680) ISPEC(:ILASCH(ISPEC))
               KERR = .TRUE.
            ELSE
               IF (J .EQ. 1) THEN
                  IVAL = -IVAL
                  RVAL = -RVAL
               ENDIF
               NNUM = 0
               IF (LRSTO) THEN
                  DO 110 K = 1, NS
                     IF (KNUM.EQ.NUNK(K,II) .AND.
     1                   RNU(K,NRNU)/RVAL.GT.0) THEN
                         NNUM = K
                         RNU(NNUM,NRNU) = RNU(NNUM,NRNU) + RVAL
                     ENDIF
  110             CONTINUE
               ELSE
                  DO 111 K = 1, NS
     1                   NU(K,II)/IVAL.GT.0) THEN
                        NNUM=K
                        NU(NNUM,II) = NU(NNUM,II) + IVAL
                     ENDIF
  111             CONTINUE
               ENDIF
C
               IF (NNUM .LE. 0) THEN
                  IF (J.EQ.1 .AND. NS.EQ.3) THEN
                     WRITE (LOUT, 690)
                     KERR = .TRUE.
                     RETURN
                  ELSEIF (J.EQ.2 .AND. NS.EQ.MAXSP) THEN
                     WRITE (LOUT, 700)
                     KERR = .TRUE.
                     RETURN
                  ELSE
                     NS = NS + 1
                     NSPEC(II) = NSPEC(II)+1
                     IF (J .EQ. 1) NREAC(II) = NS
                     NUNK(NS,II) = KNUM
                     IF (LRSTO) THEN
                        RNU(NS,NRNU) = RVAL
                     ELSE
                        NU(NS,II)   = IVAL
                     ENDIF
                  ENDIF
               ENDIF
            ENDIF
            NSTART = N
            GO TO 505
C
  510    CONTINUE
  600 CONTINUE
C
      NSPEC(II) = IR*NSPEC(II)
      RETURN
      END
      SUBROUTINE CKAUXL (SUB, NSUB, II, KK, KNAME, LOUT, MAXSP, NPAR,
      DIMENSION NSPEC(*), ITHB(*), NTBS(*), NKTB(MAXTB,*), IDUP(*),
     1          AIK(MAXTB,*), IFAL(*), IFOP(*), PFAL(NFAR,*),
     2          ILAN(*), PLAN(NLAR,*), IREV(*), RPAR(NPAR,*), IRLT(*),
     3          RLAN(NLAR,*), IWL(*), WL(*), VAL(1), IORD(*),
     4          KORD(MAXORD,*), RORD(MAXORD,*), NUNK(MAXSP,*),
     5          NU(MAXSP,*), IRNU(*), RNU(MAXSP,*)
C
      DIMENSION IEIM(*), ITDEP(*), IJAN(*), PJAN(NJAR,*), IFT1(*),
     1          PFT1(NF1R,*), IEXC(*), PEXC(*)
C
      CHARACTER*(*) SUB(*), KNAME(*)
      CHARACTER*80 KEY, RSTR, ISTR
      CHARACTER UPCASE*4
      LOGICAL KERR, LLAN, LRLT, LTHB, LFAL, LTRO, LSRI, LWL, LREV,
     1        LFORD, LRORD, LEIM, LJAN, LFT1, LEXC
C
      LTHB = (NTHB.GT.0 .AND. ITHB(NTHB).EQ.II)
      LFAL = (NFAL.GT.0 .AND. IFAL(NFAL).EQ.II)
      LWL  = (NWL .GT.0 .AND. IWL(NWL)  .EQ.II)
      LREV = (NREV.GT.0 .AND. IREV(NREV).EQ.II)
      LLAN = (NLAN.GT.0 .AND. ILAN(NLAN).EQ.II)
      LRLT = (NRLT.GT.0 .AND. IRLT(NRLT).EQ.II)
      LTRO = (NFAL.GT.0 .AND. IFAL(NFAL).EQ.II .AND. IFOP(NFAL).GT.2)
      LSRI = (NFAL.GT.0 .AND. IFAL(NFAL).EQ.II .AND. IFOP(NFAL).EQ.2)
      LEIM = (NEIM.GT.0 .AND. IEIM(NEIM).EQ.II)
      LJAN = (NJAN.GT.0 .AND. IJAN(NJAN).EQ.II)
      LFT1 = (NFT1.GT.0 .AND. IFT1(NFT1).EQ.II)
      LEXC = (NEXC.GT.0 .AND. IEXC(NEXC).EQ.II)
C
      DO 500 N = 1, NSUB
         ILEN = ILASCH(SUB(N))
         KEY = '; ';
C
         IF ( UPCASE(SUB(N), 3) .EQ. ';DUP';) THEN
            IDUP(II) = -1
            WRITE (LOUT, 4000)
            GO TO 500
         ELSE
            I2 = INDEX(SUB(N)(I1+1:),';/';)
            IF (I1.LE.0 .OR. I2.LE.0) THEN
               KERR = .TRUE.
               WRITE (LOUT, 2090) SUB(N)(:ILEN)
               GO TO 500
            ENDIF
            KEY = SUB(N)(:I1-1)
            RSTR = '; ';
            RSTR = SUB(N)(I1+1:I1+I2-1)
         ENDIF
C
         IF (UPCASE(KEY, 3).EQ.';LOW'; .OR.
     1       UPCASE(KEY, 4).EQ.';TROE';.OR.
     2       UPCASE(KEY, 3).EQ.';SRI';) THEN
            IF ((.NOT.LFAL) .OR. LLAN .OR. LRLT .OR. LREV) THEN
               KERR = .TRUE.
               IF (.NOT. LFAL) WRITE (LOUT, 1050) SUB(N)(:ILEN)
               IF (LLAN)       WRITE (LOUT, 1060) SUB(N)(:ILEN)
               IF (LRLT)       WRITE (LOUT, 1070) SUB(N)(:ILEN)
               IF (LREV)       WRITE (LOUT, 1090) SUB(N)(:ILEN)
            ELSE
C
               IF (UPCASE(KEY, 3) .EQ. ';LOW';) THEN
                  IF (IFOP(NFAL) .GT. 0) THEN
                     WRITE (LOUT, 2000) SUB(N)(:ILEN)
                     KERR = .TRUE.
                  ELSE
                     IFOP(NFAL) = ABS(IFOP(NFAL))
                     CALL IPPARR (RSTR,1,3,PFAL(1,NFAL),NVAL,IER,LOUT)
                     WRITE (LOUT, 3050) (PFAL(L,NFAL),L=1,3)
                  ENDIF
C
               ELSEIF (UPCASE(KEY, 4) .EQ. ';TROE';) THEN
                  IF (LTRO .OR. LSRI) THEN
                     KERR = .TRUE.
                     IF (LTRO) WRITE (LOUT, 2010) SUB(N)(:ILEN)
                     IF (LSRI) WRITE (LOUT, 2030) SUB(N)(:ILEN)
                  ELSE
                     LTRO = .TRUE.
                     CALL IPPARR (RSTR,1,-4,PFAL(4,NFAL),NVAL,IER,LOUT)
                     IF (NVAL .EQ. 3) THEN
                        IFOP(NFAL) = 3*IFOP(NFAL)
                        WRITE (LOUT, 3080) (PFAL(L,NFAL),L=4,6)
                     ELSEIF (NVAL .EQ. 4) THEN
                        IFOP(NFAL) = 4*IFOP(NFAL)
                        WRITE (LOUT, 3090) (PFAL(L,NFAL),L=4,7)
                     ELSE
                        WRITE (LOUT, 2020) SUB(N)(:ILEN)
                        KERR = .TRUE.
                     ENDIF
                  ENDIF
C
               ELSEIF (UPCASE(KEY, 3) .EQ. ';SRI';) THEN
                     KERR = .TRUE.
                     IF (LTRO) WRITE (LOUT, 2030) SUB(N)(:ILEN)
                     IF (LSRI) WRITE (LOUT, 2040) SUB(N)(:ILEN)
                  ELSE
                     LSRI = .TRUE.
                     IFOP(NFAL) = 2*IFOP(NFAL)
                     CALL IPPARR (RSTR,1,-5,PFAL(4,NFAL),NVAL,IER,LOUT)
                        PFAL(7,NFAL) = 1.0
                        PFAL(8,NFAL) = 0.0
                        WRITE (LOUT, 3060) (PFAL(L,NFAL),L=4,6)
                     ELSEIF (NVAL .EQ. 5) THEN
                        WRITE (LOUT, 3070) (PFAL(L,NFAL),L=4,8)
                     ELSE
                        KERR = .TRUE.
                     ENDIF
                  ENDIF
               ENDIF
            ENDIF
C
         ELSEIF (UPCASE(KEY, 3) .EQ. ';REV';) THEN
            IF (LFAL .OR. LREV .OR. NSPEC(II).LT.0) THEN
               KERR = .TRUE.
               IF (LFAL) WRITE (LOUT, 1090) SUB(N)(:ILEN)
               IF (LREV) WRITE (LOUT, 2050) SUB(N)(:ILEN)
               IF (NSPEC(II) .LT. 0) WRITE (LOUT, 2060) SUB(N)(:ILEN)
            ELSE
               LREV = .TRUE.
               NREV = NREV+1
               IREV(NREV) = II
               CALL IPPARR (RSTR,1,NPAR,RPAR(1,NREV),NVAL,IER,LOUT)
               WRITE (LOUT, 1900) ';   Reverse Arrhenius coefficients:';,
     1                           (RPAR(L,NREV),L=1,3)
            ENDIF
C
         ELSEIF (UPCASE(KEY, 3) .EQ. ';RLT';) THEN
            IF (LFAL .OR. LRLT .OR. NSPEC(II).LT.0) THEN
               KERR = .TRUE.
               IF (LFAL) WRITE (LOUT, 1070) SUB(N)(:ILEN)
               IF (LRLT) WRITE (LOUT, 2080) SUB(N)(:ILEN)
               IF (NSPEC(II) .LT. 0) WRITE (LOUT, 1080) SUB(N)(:ILEN)
            ELSE
               LRLT = .TRUE.
               NRLT = NRLT + 1
               IRLT(NRLT) = II
               CALL IPPARR (RSTR,1,NLAR,RLAN(1,NRLT),NVAL,IER,LOUT)
               WRITE (LOUT, 3040) (RLAN(L,NRLT),L=1,2)
            ENDIF
C
         ELSEIF (UPCASE(KEY, 2) .EQ. ';HV';) THEN
            IF (.NOT.LWL) THEN
               WRITE (LOUT, 1000) SUB(N)(:ILEN)
               KERR = .TRUE.
            ELSE
               CALL IPPARR (RSTR,1,1,VAL,NVAL,IER,LOUT)
                  WL(NWL) = WL(NWL)*VAL(1)
                  WRITE (LOUT, 3020) ABS(WL(NWL))
               ELSE
                  KERR = .TRUE.
               ENDIF
            ENDIF
C
         ELSEIF (UPCASE(KEY, 2) .EQ. ';LT';) THEN
            IF (LFAL .OR. LLAN) THEN
               KERR = .TRUE.
               IF (LFAL) WRITE (LOUT, 1060) SUB(N)(:ILEN)
               IF (LLAN) WRITE (LOUT, 2070) SUB(N)(:ILEN)
            ELSE
               LLAN = .TRUE.
               NLAN = NLAN + 1
               ILAN(NLAN) = II
               CALL IPPARR (RSTR,1,NLAR,PLAN(1,NLAN),NVAL,IER,LOUT)
               IF (IER .NE. 0) THEN
                  WRITE (LOUT, 1010) SUB(N)(:ILEN)
                  KERR = .TRUE.
               ENDIF
               WRITE (LOUT, 3000) (PLAN(L,NLAN),L=1,2)
            ENDIF
C
         ELSEIF (UPCASE(KEY,4).EQ.';FORD'; .OR.
     1           UPCASE(KEY,4).EQ.';RORD';) THEN
             LFORD = (UPCASE(KEY,4) .EQ. ';FORD';)
             LRORD = (UPCASE(KEY,4) .EQ. ';RORD';)
             IF (LRORD .AND. NSPEC(II).LT.0) THEN
                KERR = .TRUE.
                WRITE (LOUT, 2065)
             ELSE
             IF (NORD.EQ.0 .OR.(NORD.GT.0 .AND. IORD(NORD).NE.II)) THEN
                NORD = NORD + 1
                IORD(NORD) = II
                NKORD = 0
C
                IF (NRNU.GT.0 .AND. IRNU(NRNU).EQ.II) THEN
                   DO 111 L = 1, 6
                      IF (NUNK(L,II) .NE. 0) THEN
                         NKORD = NKORD + 1
                         IF (RNU(L,NRNU) .LT. 0.0) THEN
                            KORD(NKORD,NORD) = -NUNK(L,II)
                            RORD(NKORD,NORD) = ABS(RNU(L,NRNU))
                         ELSE
                            KORD(NKORD,NORD) = NUNK(L,II)
                            RORD(NKORD,NORD) = RNU(L,NRNU)
                         ENDIF
                      ENDIF
  111              CONTINUE
               ELSE
                   DO 113 L = 1, 6
                         NKORD = NKORD + 1
                         IF (NU(L,II) .LT. 0) THEN
                            RORD(NKORD,NORD) =  IABS(NU(L,II))
                         ELSE
                            RORD(NKORD,NORD) = NU(L,II)
                         ENDIF
                      ENDIF
  113              CONTINUE
                ENDIF
             ENDIF
             ENDIF
C
             CALL IPNPAR (RSTR, 1, ISTR, ISTART)
             IF (ISTART .GE. 1) THEN
                CALL IPPARR (ISTR, 1, 1, VAL, NVAL, IER, LOUT)
                CALL CKCOMP (RSTR(:ISTART-1), KNAME, KK, K)
                IF (LFORD) K = -K
                NK = 0
                DO 121 L = 1, MAXORD
C
                   IF (KORD(L,NORD).EQ.0) THEN
                      NK = L
                      GO TO 122
                   ELSEIF (KORD(L,NORD).EQ.K) THEN
                      IF (LFORD) THEN
                         WRITE (LOUT,*)
     1';       Warning...changing order for reactant...';,
     2                   KNAME(IABS(K))
                      ELSE
                         WRITE (LOUT,*)
     1';       Warning...changing order for product...';,
     2                   KNAME(K)
                      ENDIF
                      NK = L
                      GO TO 122
                   ENDIF
  121           CONTINUE
  122           CONTINUE
                KORD(NK,NORD) = K
                RORD(NK,NORD) = VAL(1)
                IF (LFORD) THEN
                   WRITE (LOUT, 3015) KNAME(IABS(K)),VAL(1)
                ELSE
                   WRITE (LOUT, 3016) KNAME(K),VAL(1)
                ENDIF
            ENDIF
C
         ELSEIF (UPCASE(KEY, 3) .EQ. ';EIM';) THEN
            NEIM = NEIM + 1
            IEIM(NEIM) = II
            IF (LTHB) THEN
               WRITE (LOUT, 1100) SUB(N)(:ILEN)
               KERR = .TRUE.
            ENDIF
            CALL IPPARI (RSTR, 1, 1, ITDEP(NEIM), NVAL, IER, LOUT)
            KERR = KERR .OR. (IER.NE.0) .OR. (NVAL.NE.1)
            WRITE (LOUT, 3100) ITDEP(NEIM)
C
         ELSEIF (UPCASE(KEY, 3) .EQ. ';JAN';) THEN
            NJAN = NJAN + 1
            IJAN(NJAN) = II
            CALL IPPARR (RSTR,1,NJAR,PJAN(1,NJAN),NVAL,IER,LOUT)
               WRITE (LOUT, 1110) SUB(N)(:ILEN)
               KERR = .TRUE.
            ENDIF
            WRITE (LOUT, 3110) (PJAN(L,NJAN), L = 1, NJAR)
C
         ELSEIF (UPCASE(KEY, 4) .EQ. ';FIT1';) THEN
            NFT1 = NFT1 + 1
            IFT1(NFT1) = II
            CALL IPPARR (RSTR,1,NF1R,PFT1(1,NFT1),NVAL,IER,LOUT)
               WRITE (LOUT, 1112) SUB(N)(:ILEN)
               KERR = .TRUE.
            ENDIF
            WRITE (LOUT, 3112) (PFT1(L,NFT1), L = 1, NF1R)
C
         ELSEIF (UPCASE(KEY, 4) .EQ. ';EXCI';) THEN
            NEXC = NEXC + 1
            IEXC(NEXC) = II
            CALL IPPARR (RSTR,1,1,PEXC(NEXC),NVAL,IER,LOUT)
            WRITE (LOUT, 3114) PEXC(NEXC)
C
         ELSE
            CALL CKCOMP (KEY, KNAME, KK, K)
            IF (K .EQ. 0) THEN
               WRITE (LOUT, 1040) KEY(:ILASCH(KEY))
               KERR = .TRUE.
            ELSE
               IF (.NOT.LTHB) THEN
                  KERR = .TRUE.
                  WRITE (LOUT, 1020) SUB(N)(:ILEN)
               ELSE
                  IF (NTBS(NTHB) .EQ. MAXTB) THEN
                     KERR = .TRUE.
                     WRITE (LOUT, 1030) SUB(N)(:ILEN)
                  ELSE
                     CALL IPPARR (RSTR, 1, 1, VAL, NVAL, IER, LOUT)
                        WRITE (LOUT, 3010) KNAME(K),VAL(1)
                        NTBS(NTHB) = NTBS(NTHB) + 1
                        NKTB(NTBS(NTHB),NTHB) = K
                        AIK(NTBS(NTHB),NTHB) = VAL(1)
                     ELSE
                        KERR = .TRUE.
                     ENDIF
                  ENDIF
               ENDIF
            ENDIF
         ENDIF
  500 CONTINUE
      END
      SUBROUTINE CKPRNT (MDIM, MAXTP, MM, ENAME, KK, KNAME, WTM,
     1                   KPHSE, KCHRG, NT, T, TLO, TMID, THI, KNCF,
     2                   ITHRM, LOUT, KERR)
      DIMENSION WTM(*), KPHSE(*), KCHRG(*), T(MAXTP,*),
     1          NT(*), KNCF(MDIM,*), IPLUS(10)
      CHARACTER*1 IPHSE(3), INUM(10)
      DATA IPHSE/';S';,';G';,';L';/
      DATA INUM/';0';,';1';,';2';,';3';,';4';,';5';,';6';,';7';,';8';,';9';/
C
      WRITE (LOUT, 400) (ENAME(M), M = 1, MM)
      WRITE (LOUT, 300)
C
      DO 100 K = 1, KK
C
         IF (T(1,K) .LT. 0.0) T(1,K) = TLO
         IF (T(2,K) .LT. 0.0) T(2,K) = TMID
         IF (T(3,K) .LT. 0.0) T(NT(K),K) = THI
         WRITE (LOUT, 500) K, KNAME(K), IPHSE(KPHSE(K)+2), KCHRG(K),
     1                    WTM(K), INT(T(1,K)), INT(T(NT(K),K)),
     2                   (KNCF(M,K),M=1,MM)
         IF (T(1,K) .GE. T(NT(K),K)) THEN
            KERR = .TRUE.
            WRITE (LOUT, 240)
         ENDIF
         IF (T(1,K) .GT. T(2,K)) THEN
            WRITE (LOUT, 250)
            KERR = .TRUE.
         ENDIF
         IF (T(NT(K),K) .LT. T(2,K)) THEN
            WRITE (LOUT, 260)
            KERR = .TRUE.
         ENDIF
         IF (.NOT. ITHRM(K)) THEN
            KERR = .TRUE.
            WRITE (LOUT, 200)
         ENDIF
         CALL CKCOMP (KNAME(K)(:1), INUM, 10, I)
         IF (I .GT. 0) THEN
            KERR = .TRUE.
            WRITE (LOUT, 210)
         ENDIF
         NPLUS = 0
         DO 50 N = 1, ILASCH(KNAME(K))
            IF (KNAME(K)(N:N) .EQ. ';+';) THEN
               NPLUS = NPLUS + 1
               IPLUS(NPLUS) = N
            ENDIF
   50    CONTINUE
         DO 60 N = 1, NPLUS
            I1 = IPLUS(N)
            IF (I1 .EQ. 1) THEN
               WRITE (LOUT, 220)
               KERR = .TRUE.
            ELSE
               IF (KNAME(K)(I1-1:I1-1) .EQ. ';(';) THEN
                  I1 = I1 + 1
                  I2 = I1 + INDEX(KNAME(K)(I1:),';)';)-1
                     CALL CKCOMP (KNAME(K)(I1:I2-1), KNAME, KK, KNUM)
                        WRITE (LOUT, 230)
                        KERR = .TRUE.
                     ENDIF
                  ENDIF
               ENDIF
               I1 = I1 + 1
               IF (N .LT. NPLUS) THEN
                  DO 55 L = N+1, NPLUS
                     I2 = IPLUS(L)
                        CALL CKCOMP (KNAME(K)(I1:I2-1),KNAME,KK,KNUM)
                           WRITE (LOUT, 230)
                           KERR = .TRUE.
                        ENDIF
                     ENDIF
   55             CONTINUE
               ENDIF
C
               I2 = ILASCH(KNAME(K))
               IF (I2 .GE. I1) THEN
                  CALL CKCOMP (KNAME(K)(I1:I2), KNAME, KK, KNUM)
                     WRITE (LOUT, 230)
                     KERR = .TRUE.
                  ENDIF
               ENDIF
            ENDIF
   60    CONTINUE
C
  100 CONTINUE
      WRITE (LOUT, 300)
      RETURN
      END
      SUBROUTINE CPREAC (II, MAXSP, NSPEC, NPAR, PAR, RPAR, AUNITS,
     1                   EUNITS, NREAC, NUNK, NU, KCHRG, MDIM, MM, KNCF,
     2                   IDUP, NFAL, IFAL, KFAL, NFAR, PFAL, IFOP, NREV,
     3                   IREV, NTHB, ITHB, NLAN, ILAN, NRLT, IRLT, KERR,
     4                   LOUT, NRNU, IRNU, RNU, CKMIN)
      DOUBLE PRECISION RU_JOUL,        AVAG,                ONE
      PARAMETER (RU_JOUL = 8.314510D0, AVAG = 6.0221367D23, ONE=1.0D0)
      DIMENSION NSPEC(*), PAR(NPAR,*), RPAR(NPAR,*), NREAC(*),
     1          NUNK(MAXSP,*), NU(MAXSP,*), KCHRG(*), KNCF(MDIM,*),
     2          IDUP(*), IFAL(*), KFAL(*), PFAL(NFAR,*), IFOP(*),
     3          IREV(*), ITHB(*), ILAN(*), IRLT(*), IRNU(*),
     4          RNU(MAXSP,*)
      CHARACTER*(*) AUNITS, EUNITS
      LOGICAL IERR,KERR,LREV,LLAN,LRLT
C
      IF (NRNU.GT.0 .AND. (II.EQ.IRNU(NRNU))) THEN
         CALL CKRBAL (MAXSP, NUNK(1,II), RNU(1,NRNU), MDIM, MM, KCHRG,
     1                KNCF, CKMIN, IERR)
      ELSE
         CALL CKBAL (MAXSP, NUNK(1,II), NU(1,II), MDIM, MM, KCHRG, KNCF,
     1               IERR)
      ENDIF
C
      IF (IERR) THEN
         KERR = .TRUE.
         WRITE (LOUT, 1060)
      ENDIF
C
      CALL CKDUP (II, MAXSP, NSPEC, NREAC, NU, NUNK, NFAL, IFAL, KFAL,
     1            ISAME)
C
      IF (ISAME .GT. 0) THEN
         IF (IDUP(ISAME).NE.0 .AND. IDUP(II).NE.0) THEN
            IDUP(ISAME) = ABS(IDUP(ISAME))
            IDUP(II)    = ABS(IDUP(II))
         ELSE
            N1 = 0
            N2 = 0
            IF (NTHB .GT. 1) THEN
               DO 150 N = 1, NTHB
                  IF (ITHB(N) .EQ. ISAME) N1 = 1
                  IF (ITHB(N) .EQ. II)    N2 = 1
  150          CONTINUE
            ENDIF
            IF (N1 .EQ. N2) THEN
               KERR = .TRUE.
               WRITE (LOUT, 1050) ISAME
            ENDIF
         ENDIF
      ENDIF
C
      IF (NFAL.GT.0 .AND. IFAL(NFAL).EQ.II .AND. IFOP(NFAL).LT.0) THEN
         KERR = .TRUE.
         WRITE (LOUT, 1020)
      ENDIF
C
      IF (LREV .AND. LLAN .AND. (.NOT.LRLT)) THEN
         KERR = .TRUE.
         WRITE (LOUT, 1030)
      ENDIF
      IF (LRLT .AND. (.NOT.LLAN)) THEN
         KERR = .TRUE.
         WRITE (LOUT, 1040)
      ENDIF
      IF (LRLT .AND. (.NOT.LREV)) THEN
         KERR = .TRUE.
         WRITE (LOUT, 1045)
      ENDIF
C
      IF (EUNITS .EQ. ';KELV';) THEN
         EFAC = 1.0
      ELSEIF (EUNITS .EQ. ';CAL/';) THEN
C        convert E from cal/mole to Kelvin
         EFAC = 4.184  / RU_JOUL
      ELSEIF (EUNITS .EQ. ';KCAL';) THEN
C        convert E from kcal/mole to Kelvin
         EFAC = 4184.0 / RU_JOUL
      ELSEIF (EUNITS .EQ. ';JOUL';) THEN
C        convert E from Joules/mole to Kelvin
         EFAC = 1.00  / RU_JOUL
      ELSEIF (EUNITS .EQ. ';KJOU';) THEN
C        convert E from Kjoules/mole to Kelvin
         EFAC = 4000.0 / RU_JOUL
      ENDIF
      PAR(3,II) = PAR(3,II) * EFAC
      IF (NREV.GT.0 .AND. IREV(NREV).EQ.II)
     1    RPAR(3,NREV) = RPAR(3,NREV) * EFAC
     1    PFAL(3,NFAL) = PFAL(3,NFAL) * EFAC
C
      IF (AUNITS .EQ. ';MOLC';) THEN
         NSTOR = 0
         NSTOP = 0
         DO 50 N = 1, MAXSP
            IF (NU(N,II) .LT. 0) THEN
C              sum of stoichiometric coefficients of reactants
               NSTOR = NSTOR + ABS(NU(N,II))
            ELSEIF (NU(N,II) .GT. 0) THEN
C              sum of stoichiometric coefficients of products
               NSTOP = NSTOP + NU(N,II)
            ENDIF
   50    CONTINUE
C
            IF (NSTOR.GT.0) PAR(1,II) = PAR(1,II) * AVAG**(NSTOR-1)
            NSTOR = NSTOR + 1
            IF (NSTOR.GT.0) PFAL(1,NFAL) = PFAL(1,NFAL)*AVAG**(NSTOR-1)
C
         ELSEIF (NTHB.GT.0 .AND. ITHB(NTHB).EQ.II) THEN
            NSTOR = NSTOR + 1
            NSTOP = NSTOP + 1
            IF (NREV.GT.0 .AND. IREV(NREV).EQ.II .AND. NSTOP.GT.0)
     1          RPAR(1,NREV) = RPAR(1,NREV) * AVAG**(NSTOP-1)
C
         ELSE
            IF (NSTOR .GT. 0) PAR(1,II) = PAR(1,II) * AVAG**(NSTOR-1)
         ENDIF
      ENDIF
      RETURN
      END
      SUBROUTINE CKBAL (MXSPEC, KSPEC, KCOEF, MDIM, MM, KCHRG, KNCF,
     1                  IERR)
      DIMENSION KSPEC(*), KCOEF(*), KNCF(MDIM,*), KCHRG(*)
      LOGICAL IERR
C
      IERR = .FALSE.
      KBAL = 0
      DO 50 N = 1, MXSPEC
         IF (KSPEC(N) .NE. 0)
     1   KBAL = KBAL + KCOEF(N)*KCHRG(KSPEC(N))
   50 CONTINUE
      IF (KBAL .NE. 0) IERR = .TRUE.
      DO 100 M = 1, MM
         MBAL = 0
         DO 80 N = 1, MXSPEC
     1      MBAL = MBAL + KCOEF(N)*KNCF(M,KSPEC(N))
   80    CONTINUE
         IF (MBAL .NE. 0) IERR = .TRUE.
  100 CONTINUE
      RETURN
      END
      SUBROUTINE CKRBAL (MXSPEC, KSPEC, RCOEF, MDIM, MM, KCHRG, KNCF,
     1                   CKMIN, IERR)
      DIMENSION KSPEC(*), RCOEF(*), KNCF(MDIM,*), KCHRG(*)
      LOGICAL IERR
C
      IERR = .FALSE.
      SBAL = 0
      DO 50 N = 1, MXSPEC
     1   SBAL = SBAL + RCOEF(N)*KCHRG(KSPEC(N))
   50 CONTINUE
      IF (ABS(SBAL) .GT. CKMIN) IERR = .TRUE.
      DO 100 M = 1, MM
         SMBAL = 0
         DO 80 N = 1, MXSPEC
     1      SMBAL = SMBAL + RCOEF(N)*KNCF(M,KSPEC(N))
   80    CONTINUE
         IF (ABS(SMBAL) .GT. CKMIN) IERR = .TRUE.
  100 CONTINUE
      RETURN
      END
      SUBROUTINE CKDUP (I, MAXSP, NS, NR, NU, NUNK, NFAL, IFAL, KFAL,
     1                  ISAME)
      DIMENSION NS(*), NR(*), NU(MAXSP,*), NUNK(MAXSP,*), IFAL(*),
     1          KFAL(*)
C
      ISAME = 0
      NRI = NR(I)
      NPI = ABS(NS(I)) - NR(I)
C
      DO 500 J = 1, I-1
C
         NRJ = NR(J)
         NPJ = ABS(NS(J)) - NR(J)
C
         IF (NRJ.EQ.NRI .AND. NPJ.EQ.NPI) THEN
C
            NSAME = 0
            DO 20 N = 1, MAXSP
               KI = NUNK(N,I)
               NI = NU(N,I)
C
               DO 15 L = 1, MAXSP
                  KJ = NUNK(L,J)
                  NJ = NU(L,J)
                  IF (NJ.NE.0 .AND. KJ.EQ.KI .AND. NJ.EQ.NI)
     1            NSAME = NSAME + 1
   15          CONTINUE
   20       CONTINUE
C
            IF (NSAME .EQ. ABS(NS(J))) THEN
               IF (NFAL.GT.0 .AND. IFAL(NFAL).EQ.I) THEN
                  DO 22 N = 1, NFAL-1
                     IF (J.EQ.IFAL(N) .AND. KFAL(N).EQ.KFAL(NFAL)) THEN
                        ISAME = J
                        RETURN
                     ENDIF
   22             CONTINUE
                  RETURN
               ENDIF
C
               ISAME = J
               RETURN
            ENDIF
         ENDIF
C
         IF (NPI.EQ.NRJ .AND. NPJ.EQ.NRI) THEN
C
            NSAME = 0
            DO 30 N = 1, MAXSP
               KI = NUNK(N,I)
               NI = NU(N,I)
C
               DO 25 L = 1, MAXSP
                  KJ = NUNK(L,J)
                  NJ = NU(L,J)
                  IF (NJ.NE.0 .AND. KJ.EQ.KI .AND. -NJ.EQ.NI)
     1            NSAME = NSAME + 1
   25          CONTINUE
   30       CONTINUE
C
            IF (NSAME.EQ.ABS(NS(J)) .AND.
     1          (NS(J).GT.0 .OR. NS(I).GT.0)) THEN
                  DO 32 N = 1, NFAL-1
                        ISAME = J
                        RETURN
                     ENDIF
   32             CONTINUE
                  RETURN
               ENDIF
C
               ISAME = J
               RETURN
            ENDIF
         ENDIF
C
  500 CONTINUE
      RETURN
      END
      SUBROUTINE CKISUB (LINE, SUB, NSUB)
      CHARACTER*(*) SUB(*), LINE
      NSUB = 0
C
      DO 5 N = 1, LEN(LINE)
        IF (ICHAR(LINE(N:N)) .EQ. 9) LINE(N:N) = '; ';
    5 CONTINUE
C
      IF (IPPLEN(LINE) .LE. 0) RETURN
C
      ILEN = ILASCH(LINE)
C
      NSTART = IFIRCH(LINE)
   10 CONTINUE
      ISTART = NSTART
      NSUB = NSUB + 1
      SUB(NSUB) = '; ';
C
      DO 100 I = ISTART, ILEN
         ILAST = INDEX(LINE(ISTART:),'; ';) - 1
         IF (ILAST .GT. 0) THEN
            ILAST = ISTART + ILAST - 1
         ELSE
            ILAST = ILEN
         ENDIF
         SUB(NSUB) = LINE(ISTART:ILAST)
         IF (ILAST .EQ. ILEN) RETURN
C
         NSTART = ILAST + IFIRCH(LINE(ILAST+1:))
         I1 = INDEX(SUB(NSUB),';/';)
         IF (I1 .LE. 0) THEN
            IF (LINE(NSTART:NSTART) .NE. ';/';) GO TO 10
            NEND = NSTART + INDEX(LINE(NSTART+1:),';/';)
            IND = INDEX(SUB(NSUB),'; ';)
            SUB(NSUB)(IND:) = LINE(NSTART:NEND)
            IF (NEND .EQ. ILEN) RETURN
            NSTART = NEND + IFIRCH(LINE(NEND+1:))
            GO TO 10
         ENDIF
         I2 = INDEX(SUB(NSUB)(I1+1:),';/';)
         IF (I2 .GT. 0) GO TO 10
C
         IND = INDEX(SUB(NSUB),'; ';) + 1
         GO TO 10
  100 CONTINUE
      RETURN
      END
      SUBROUTINE IPNPAR (LINE, NPAR, IPAR, ISTART)
      CHARACTER*(*) LINE,IPAR
      ILEN = IPPLEN(LINE)
      ISTART = 0
      N = 0
      IF (ILEN.GT.0) THEN
         DO 40 I = ILEN, 1, -1
            ISTART = I
            IPAR = '; ';
            IPAR = LINE(ISTART:ILEN)
            IF (LINE(I:I).NE.'; ';) THEN
               IF (I .EQ. 1) RETURN
               IF (LINE(I-1:I-1) .EQ. '; ';) THEN
                  N = N + 1
                  IF (N .EQ. NPAR) RETURN
               ENDIF
            ENDIF
   40    CONTINUE
      ENDIF
      RETURN
      END
      SUBROUTINE IPPARI(STRING, ICARD, NEXPEC, IVAL, NFOUND, IERR, LOUT)
      CHARACTER*(*) STRING
      CHARACTER ITEMP*80
      DIMENSION IVAL(*)
      CHARACTER *8 FMT(14)
      LOGICAL OKINCR
      IERR   = 0
      NFOUND = 0
      NEXP = IABS(NEXPEC)
      IE = ILASCH(STRING)
      IF (IE .EQ. 0) GO TO 500
      NC = 1
      OKINCR = .TRUE.
100   CONTINUE
      IF (STRING(NC:NC) .EQ. ';,';) THEN
         IF (OKINCR .OR. NC .EQ. IE) THEN
            NFOUND = NFOUND + 1
         ELSE
            OKINCR = .TRUE.
         ENDIF
C
         GO TO 450
      ENDIF
      IF (STRING(NC:NC) .EQ. '; ';) GO TO 450
      IBS = NC
160   CONTINUE
      NC = NC + 1
      IF (NC .GT. IE) GO TO 180
      IF (STRING(NC:NC) .EQ. '; ';)THEN
         OKINCR = .FALSE.
      ELSEIF (STRING(NC:NC) .EQ. ';,';)THEN
         OKINCR = .TRUE.
      ELSE
         GO TO 160
      ENDIF
180   CONTINUE
      NFOUND = NFOUND + 1
      IF (NFOUND .GT. NEXP) THEN
         IERR = 3
         GO TO 500
      ENDIF
C
      IES = NC - 1
      NCH = IES - IBS + 1
      DATA FMT/'; (I1)';, '; (I2)';, '; (I3)';, '; (I4)';, '; (I5)';,
     1   '; (I6)';, '; (I7)';, '; (I8)';, '; (I9)';, ';(I10)';,
     2   ';(I11)';, ';(I12)';, ';(I13)';, ';(I14)';/
      ITEMP = '; ';
      ITEMP = STRING(IBS:IES)
      READ (ITEMP(1:NCH), FMT(NCH), ERR = 400) IVAL(NFOUND)
      GO TO 450
400   CONTINUE
      IERR = 1
      GO TO 510
450   CONTINUE
      NC = NC + 1
      IF (NC .LE. IE) GO TO 100
C
500   CONTINUE
      IF (NEXPEC .GT. 0 .AND. NFOUND .LT. NEXP) IERR = 2
510   CONTINUE
C
      IF (IERR .EQ. 0 .OR. ICARD .LT. 0)RETURN
      IF (ICARD .NE. 0) WRITE (LOUT, ';(A,I3)';)
     1   ';!! ERROR IN DATA STATEMENT NUMBER';, ICARD
      IF (IERR .EQ. 1)
     1    WRITE (LOUT, ';(A)';)';SYNTAX ERROR, OR ILLEGAL VALUE';
      IF (IERR .EQ. 2) WRITE (LOUT, ';(A,I2, A, I2)';)
     1   '; TOO FEW DATA ITEMS.  NUMBER FOUND = '; , NFOUND,
     2   ';  NUMBER EXPECTED = ';, NEXPEC
      IF (IERR .EQ. 3) WRITE (LOUT, ';(A,I2)';)
     1   '; TOO MANY DATA ITEMS.  NUMBER EXPECTED = ';, NEXPEC
      END
C
      SUBROUTINE IPPARR(STRING, ICARD, NEXPEC, RVAL, NFOUND, IERR, LOUT)
      CHARACTER ITEMP*80
      DIMENSION RVAL(*)
      CHARACTER *8 FMT(22)
      LOGICAL OKINCR
C
C   FIRST EXECUTABLE STATEMENT  IPPARR
      IERR   = 0
      NFOUND = 0
      NEXP = IABS(NEXPEC)
      IE = ILASCH(STRING)
      NC = 1
      OKINCR = .TRUE.
100   CONTINUE
         IF (OKINCR) THEN
            NFOUND = NFOUND + 1
         ELSE
            OKINCR = .TRUE.
         ENDIF
C
         GO TO 450
      ENDIF
      IBS = NC
160   CONTINUE
      NC = NC + 1
         OKINCR = .FALSE.
         OKINCR = .TRUE.
      ELSE
         GO TO 160
      ENDIF
180   CONTINUE
      NFOUND = NFOUND + 1
         IERR = 3
         GO TO 500
      ENDIF
C
      DATA FMT/     '; (E1.0)';, '; (E2.0)';, '; (E3.0)';, '; (E4.0)';,
     1   '; (E5.0)';, '; (E6.0)';, '; (E7.0)';, '; (E8.0)';, '; (E9.0)';,
     2   ';(E10.0)';, ';(E11.0)';, ';(E12.0)';, ';(E13.0)';, ';(E14.0)';,
     3   ';(E15.0)';, ';(E16.0)';, ';(E17.0)';, ';(E18.0)';, ';(E19.0)';,
     4   ';(E20.0)';, ';(E21.0)';, ';(E22.0)';/
      IES = NC - 1
      NCH = IES - IBS + 1
      ITEMP = '; ';
      READ (ITEMP(1:NCH), FMT(NCH), ERR = 400) RVAL(NFOUND)
      GO TO 450
400   CONTINUE
      WRITE (LOUT, 555) STRING(IBS:IES)
  555 FORMAT (A)
      IERR = 1
      GO TO 510
450   CONTINUE
      NC = NC + 1
C
500   CONTINUE
510   CONTINUE
C
      IF (IERR .EQ. 0 .OR. ICARD .LT. 0) RETURN
      IF (IERR .EQ. 1)
      END
C
      FUNCTION IFIRCH(STRING)
      CHARACTER* (*)STRING
C
C   FIRST EXECUTABLE STATEMENT IFIRCH
      NLOOP = LEN(STRING)
C
      IF (NLOOP .EQ. 0) THEN
         IFIRCH = 0
         RETURN
      ENDIF
C
      DO 100 I = 1, NLOOP
         IF (STRING(I:I) .NE. '; ';) GO TO 120
100   CONTINUE
C
      IFIRCH = 0
      RETURN
120   CONTINUE
      IFIRCH = I
      END
      FUNCTION ILASCH(STRING)
       NLOOP = LEN(STRING)
      IF (NLOOP.EQ.0) THEN
         ILASCH = 0
         RETURN
      ENDIF
C
      DO 100 I = NLOOP, 1, -1
100   CONTINUE
C
120   CONTINUE
      ILASCH = I
      END
      SUBROUTINE CKCOMP (IST, IRAY, II, I)
      CHARACTER*(*) IST, IRAY(*)
C
      I = 0
      DO 10 N = II, 1, -1
         IS1 = IFIRCH(IST)
         IS2 = ILASCH(IST)
         IR1 = IFIRCH(IRAY(N))
         IR2 = ILASCH(IRAY(N))
         IF ( IS2.GE.IS1 .AND. IS2.GT.0 .AND.
     1        IR2.GE.IR1 .AND. IR2.GT.0 .AND.
     2        IST(IS1:IS2).EQ.IRAY(N)(IR1:IR2) ) I=N
   10 CONTINUE
      RETURN
      END
      SUBROUTINE CKUNIT (LINE, AUNITS, EUNITS, IUNITS)
      CHARACTER*(*) LINE, IUNITS, AUNITS, EUNITS
      CHARACTER*4 UPCASE
C
      AUNITS = '; ';
      EUNITS = '; ';
      IUNITS = '; ';
      LCHAR = ILASCH(LINE)
      DO 85 N = 1, ILASCH(LINE)-3
         IND = ILASCH(IUNITS)
         IF (EUNITS .EQ. '; ';) THEN
            IF (UPCASE(LINE(N:), 4)     .EQ. ';CAL/';) THEN
               EUNITS = ';CAL/';
               IF (IUNITS .EQ. '; ';) THEN
                  IUNITS = ';E units cal/mole';
               ELSE
                  IUNITS(IND:) = ';, E units cal/mole';
               ENDIF
            ELSEIF (UPCASE(LINE(N:), 4) .EQ. ';KCAL';) THEN
               EUNITS = ';KCAL';
                  IUNITS = ';E units Kcal/mole';
               ELSE
                  IUNITS(IND:) = ';, E units Kcal/mole';
               ENDIF
            ELSEIF (UPCASE(LINE(N:), 4) .EQ. ';JOUL';) THEN
               EUNITS = ';JOUL';
                  IUNITS = ';E units Joules/mole';
               ELSE
                  IUNITS(IND:) = ';, E units Joules/mole';
               ENDIF
            ELSEIF (UPCASE(LINE(N:), 4) .EQ. ';KJOU';) THEN
               EUNITS = ';KJOU';
                  IUNITS = ';E units Kjoule/mole';
               ELSE
                  IUNITS(IND:) = ';, E units Kjoule/mole';
               ENDIF
            ELSEIF (UPCASE(LINE(N:), 4) .EQ. ';KELV';) THEN
               EUNITS = ';KELV';
                  IUNITS = ';E units Kelvins';
               ELSE
                  IUNITS(IND:) = ';, E units Kelvins';
               ENDIF
            ENDIF
         ENDIF
         IF (AUNITS .EQ. '; ';) THEN
            IF (UPCASE(LINE(N:), 4) .EQ. ';MOLE';) THEN
               IF (N+4.LE.ILASCH(LINE) .AND.
     1                    UPCASE(LINE(N+4:),1).EQ.';C';) THEN
C
                  AUNITS = ';MOLC';
                     IUNITS = ';A units molecules';
                  ELSE
                      IUNITS(IND:) = ';, A units molecules';
                  ENDIF
               ELSE
                  AUNITS = ';MOLE';
                     IUNITS = ';A units mole-cm-sec-K';
                  ELSE
                     IUNITS(IND:) = ';, A units mole-cm-sec-K';
                  ENDIF
               ENDIF
            ENDIF
         ENDIF
   85 CONTINUE
C
         AUNITS = ';MOLE';
         IND = ILASCH(IUNITS) + 1
         IF (IND .GT. 1) THEN
         ELSE
            IUNITS(IND:) = '; A units mole-cm-sec-K';
         ENDIF
      ENDIF
C
         EUNITS = ';CAL/';
         ELSE
            IUNITS(IND:) = '; E units cal/mole';
         ENDIF
      ENDIF
C
      RETURN
      END
C
C
      INTEGER FUNCTION IPPLEN (LINE)
C
C  BEGIN PROLOGUE
C
C  FUNCTION IPPLEN (LINE)
C     Returns the effective length of a character string, i.e.,
C     the index of the last character before an exclamation mark (!)
C     indicating a comment.
C
C  INPUT
C     LINE  - A character string.
C
C  OUTPUT
C     IPPLEN - The effective length of the character string.
C
C  END PROLOGUE
C
C*****END precision > double
C*****precision > single
C      IMPLICIT REAL (A-H,O-Z), INTEGER (I-N)
C*****END precision > single
C
      CHARACTER*(*) LINE
C
      IN = IFIRCH(LINE)
      IF (IN.EQ.0 .OR. LINE(IN:IN).EQ.';!';) THEN
         IPPLEN = 0
      ELSE
         IN = INDEX(LINE,';!';)
         IF (IN .EQ. 0) THEN
            IPPLEN = ILASCH(LINE)
         ELSE
            IPPLEN = ILASCH(LINE(:IN-1))
         ENDIF
      ENDIF
      RETURN
      END
C
      CHARACTER*(*) FUNCTION UPCASE(ISTR, ILEN)
      CHARACTER*(*) ISTR
      CHARACTER*1 LCASE(26), UCASE(26)
      DATA LCASE /';a';,';b';,';c';,';d';,';e';,';f';,';g';,';h';,';i';,';j';,';k';,';l';,';m';,
     1            ';n';,';o';,';p';,';q';,';r';,';s';,';t';,';u';,';v';,';w';,';x';,';y';,';z';/,
     2     UCASE /';A';,';B';,';C';,';D';,';E';,';F';,';G';,';H';,';I';,';J';,';K';,';L';,';M';,
     3            ';N';,';O';,';P';,';Q';,';R';,';S';,';T';,';U';,';V';,';W';,';X';,';Y';,';Z';/
C
      UPCASE = '; ';
      UPCASE = ISTR(:ILEN)
      JJ = MIN (LEN(UPCASE), LEN(ISTR), ILEN)
      DO 10 J = 1, JJ
         DO 10 N = 1,26
            IF (ISTR(J:J) .EQ. LCASE(N)) UPCASE(J:J) = UCASE(N)
   10 CONTINUE
      RETURN
      END
 楼主| 发表于 2005-5-6 21:29:52 | 显示全部楼层
Chemkin-II的源程序使用不太容易,
发现困难可以与我联系
发表于 2005-5-6 22:44:45 | 显示全部楼层
非常感谢洪教授的无私奉献,
以后还得向您多多请教!
发表于 2005-5-12 20:43:38 | 显示全部楼层
请问这里是全部代码嘛?
发表于 2005-5-19 00:16:27 | 显示全部楼层
    WRITE (LOUT, 333)
333   CONTINUE
      编译时出现错误,请赐教。
发表于 2005-5-19 14:49:17 | 显示全部楼层
很多编译错误,都是写文件的标号缺少对应的format格式,如333、1800等等
发表于 2005-5-24 22:05:34 | 显示全部楼层
好像这里只是一部分代码
