查看: 2457|回复: 3
[求助]怎么找到各类重金属氯盐与CaO、SiO2反应的速率常数
发表于 2007-6-11 13:23:25 | 显示全部楼层 |阅读模式
我用CHEMKIN4.0作重金属氯盐与CaO、SiO2反应的热力学和动力学计算,不知怎么找到各类重金属氯盐与CaO、SiO2反应的速率常数,那位高手帮帮忙,谢谢
发表于 2007-6-11 19:53:43 | 显示全部楼层
try NIST Chemical Kinetics Database to begin with.
 楼主| 发表于 2007-6-12 08:58:52 | 显示全部楼层
Thank you!But there is only organic compound.
发表于 2007-6-12 21:10:12 | 显示全部楼层
CHEMKIN is originally developed and predominatedly used for gas-phase reactions. The cloest for your case I can think of would be Sandia condensed-phase data file. You may also try your luck in the Reaction Design online user forum. Are you doing this for electrochemistry or material surface reactions?
