查看: 3930|回复: 5
04-06里面的chimera 请教!
发表于 2006-12-26 09:01:39 | 显示全部楼层 |阅读模式
04-06里面的chimera 请教!
在04里面chimera做好了 可是导入到06后
有一个区总是提示hole cutting的时候“entire zone blank out”
何解?
谢谢!
 楼主| 发表于 2006-12-28 19:07:11 | 显示全部楼层
04-06里面的chimera 请教!
[这个贴子最后由ericzq6159在 2006/12/28 07:35pm 第 1 次编辑]
  xxx Identifying Chimera Boundary Cells in Zone            6
     >>> Entire zone was blanked out while cutting a chimera hole
     >>> Perturbed the Grid by   8.878020345727922E-005
     >>> Perturbed the Grid by   1.775604069145584E-004
     >>> Perturbed the Grid by   2.663406103718377E-004
     >>> Perturbed the Grid by   3.551208138291169E-004
     >>> Perturbed the Grid by   4.439010172863961E-004
     >>> Perturbed the Grid by   5.326812207436753E-004
     >>> Perturbed the Grid by   6.214614242009545E-004
     >>> Perturbed the Grid by   7.102416276582338E-004
     >>> Perturbed the Grid by   8.878020345727923E-004
     >>> Perturbed the Grid by   1.065362441487351E-003
     >>> Perturbed the Grid by   1.242922848401909E-003
     >>> Perturbed the Grid by   1.420483255316468E-003
     >>> Perturbed the Grid by   1.598043662231026E-003
     >>> Perturbed the Grid by   1.775604069145585E-003
     >>> Perturbed the Grid by   1.953164476060143E-003
     >>> Perturbed the Grid by   2.130724882974701E-003
     >>> Perturbed the Grid by   2.308285289889259E-003
[ERROR]: (blank_cells) Hole-cutting failed repeatedly for this zone.
这是错误信息
希望高手给指点下 谢谢!
 楼主| 发表于 2006-12-30 22:23:45 | 显示全部楼层
04-06里面的chimera 请教!
问题已经解决,谢谢
发表于 2007-1-6 15:27:47 | 显示全部楼层
04-06里面的chimera 请教!
怎么解决的?请教!
发表于 2007-3-20 17:09:02 | 显示全部楼层
04-06里面的chimera 请教!
下面引用由ericzq6159在 2006/12/30 10:23pm 发表的内容:
问题已经解决,谢谢
 楼主| 发表于 2007-3-26 18:03:47 | 显示全部楼层
04-06里面的chimera 请教!
修改网格密度,在chimera重叠的地方
网格密度要求非常高!
