查看: 4256|回复: 4
求助:怎么破解cfd2003阿?
发表于 2006-1-22 21:02:52 | 显示全部楼层 |阅读模式
我按照crack里面的要求做,但是不行啊!
发表于 2006-2-19 09:29:53 | 显示全部楼层
求助:怎么破解cfd2003阿?
CFDRC 2003
1. Run setup and select all options. When prompted for license
   type select floating. You will be asked to type in your
   hostname. If you are not on a domain just type in you
   host name with no other characters. If your on a domain
   then type in the full qualified path. See the getting started
   PDF in the root directory of the CD.
2. Install Python.
3. Install MPICH only if you have network with more than two
   computers.
4. Open the crack directory and copy the lservrc file to
   C:\Program Files\CFDRC\V2003\licensing.
5. Reboot and run the program.
6. Optional: Open the tutorial folder and run setup
   to install the tutorial.
如果按照以上的方法操作还是不行,就得改一些环境变量了
发表于 2006-2-19 10:01:24 | 显示全部楼层
求助:怎么破解cfd2003阿?
請問何為環境變量呀?
謝謝
发表于 2006-2-28 16:10:18 | 显示全部楼层
求助:怎么破解cfd2003阿?
右键单击我的电脑,点击属性,打开属性对话框。选中高级选项卡,点击环境变量按钮。
在系统变量中添加如下项目:
变量          值
CFDRCDIR  软件安装目录,由实际情况而定(如c:\CFDRC\V2003)
LSCFDRC   计算机名称(网上邻居中显示的名称)
P_SCHEMA   schema目录,由实际情况而定(如c:\CFDRC\V2003\schema)
PYTHONPATH  ScriptLanguage目录,由实际情况而定(如c:\CFDRC\V2003\ScriptLanguage)
发表于 2006-10-10 07:57:29 | 显示全部楼层
求助:怎么破解cfd2003阿?
我安装的经验是按楼上所说的步骤操作后,也就是重启之后,启动lincense manager,点击floating,弹出界面Install server,则开始start server,即enjoy it !
